Fridge mount
Jeff Dodgen
I have a used ARB FridgeFreeze that I obtained and I want a way to mount it in my rig. It says MT-30 on it and I am having a hard time identifying it through websites. Is anyone here familiar with this model and know of a mount, not slide, that will work with this fridge? I have looked at an Engel mount that replaces the feet on my fridge and wondered if that will work. I am also open to see any homebrew solutions. I really only need a hard mount but want something cleaner that just a rachet strap across the top. Thanks.
Corey
OverCamping Specialist
I have the Engel Slide Lock (non sliding) for my 45 qt old school ARB fridge.
You would probably have to call them up to see which mount as they make a few sizes will fit your ARB fridge.
ARB (old school style) and Engels are the same, so you would have to match your qt size to get the right ont.
http://www.engel-usa.com/index.php?...n=com_virtuemart&Itemid=59&vmcchk=1&Itemid=59
nuclearlemon
i had some hooks from bungee straps over the handles and hooked to turnbuckles that go down to the tie down rails mounted on my storage cubbys
off-roader
The new ARB 50Qt fridge uses a new mount. Instead of a costly mount, I use a different system... handles mounted to the floor ((B) in the picture below) of my sleeping/storage platform are strong enough to use ratcheting tie down straps to hold the fridge in place even over the bounciest terrain.
gp01
