How much off road can they handle?
Redline
Likes to Drive and Ride
Lots of good replies. While there are certainly limitations when traveling off-highway in a big, long, wide truck, the camper load is a much bigger concern/issue than the truck itself in my book. Just like all the other guys have said.
This old F350 has seen numerous off-highway miles over the past 16 years, most of it relatively lightly loaded (recovery gear, tools, fuel) never enough weight to hurt it's performance. A camper would be a different story.
bob91yj
Resident **************
IMO you are going to reduce the usable life of ANY slide in camper taking it off road. My SunLite pop up is actually designed for a mini truck, it's lighter and narrower than most slide in's. Opening the camper door for the first time after traveling down a dirt road is always an adventure....what did I forget to secure adequately, what rattled loose, did the lock on the 'fridge door hold, is the roof air laying in the middle of the floor? To date, my camper has held up better than expected, a shattered jar of pickles laying in the floor is the worst thing I've found.
I had grand ideas about how I was going to use this set up. The reality of it has limited it's use. If I'm covering a lot of ground off road and camping along the way, the Jeep and a tent usually get the call. If I'm base camping and it requires some light/moderate dirt road travel to get there, I'll take the truck/camper and tow the Jeep (either flat tow or in a 24' enclosed trailer).
The only real abuse the truck/camper get is chase truck duties for the Baja 500/1000. It's still mostly pavement travel, but when I do get in the dirt I travel at the fastest possible speed (often times a fast walk), cringing at every rut/bump along the way. The camper is loaded HEAVY for these events. The couch/bed space gets loaded with tools/parts etc.
So far (3 years) it has held up to the task without falling apart.
If you decide on going with a slide in camper (hard side or pop up), I'd set your expectations for off road capabilities low and be happy when it outperforms your baseline. Would I buy another slide in...yes, without a doubt. We are happy with the comfort/convenience of ours. Mine would be a little small for your plans. Just enough room for two adults and two Boxer dogs in ours. Adding our grandson to the mix when he's old enough will be interesting...the dogs aren't going to be happy about losing their bed!
jefe4x4
Redline,
You made my case with the pic of your F-truck. See the way the frame is twisting and taking the bed with it? I see a lot less of that with my Dodge as the twisting is transfered more to the suspension, but when it does flex, and it does, I take precautions to make sure the tie downs don't get undue torque. The frame of my camper is still rigid and I'd like it to stay that way.
I live in the same town and have talked to Gary and Monika Wescott (Turtle Expedition) and followed their exploits for the last 35 years. They may be the original Expo camper people. They have tried every version of campers from hard sides to pop ups and now use a frame mounted, 3 point attachment system on their custom made camper box. Since it's frame mounted you could not call it a truck camper anymore. If the box was removed there would be no 'pickup' use of the truck. It is one sweet purpose built rig. Everything they have done to 'make-it-work' has come through the school of trial-and-error, and hard knocks. They took a Ford 3/4T P.U. with short, skinny little AT tires on a trans-Siberian trek some years ago and found they needed MUCH bigger tires and clearance, like the ruskies use on their Trans-Siberian winter trucks. They also found that the weight and top clearance savings by using a 4Wheel camper was not worth the leaking, frigid, wind-blown agony. You'll notice now that they have huge tires on an F-550 chassis and completely weather-proof box. I am simply in awe. However, I'm simply not in their league, money wise. I had to do it on the cheap and incrementally.
I notice the 9' Alpenlite mudmony above seems to have a heavy camper with a basement, probably 1200 lbs. heavier than mine. This set up is doomed to fail, off-road. Also, bob91Y with the AC on his little camper; doomed.
We all come from a different vantage point and experience. I was a hard-core jeeper (small j sometimes) since 1965. When we became a family, I switched to larger, family size camping/jeeping rigs. We made a lot of 'way-out-there' trips in those rigs. After the kids were grown and in stage two (1. out of the house. 2. out of my pocket), I bought a pickup to flat tow my rock crawler, then bought a car trailer to haul the jeep. Then, as I was getting older and softer, laying on the ground in the snow or dust at the end of a day's crawling held less appeal. Enter the hard side camper. This is where I started to use the physics of jeeping and apply them to a wondrously improbable off-road, hard side truck camper. The physics of a 1800 lb. white box on the back of a short bed pick up made no sense at all. But, therein lain the challenge. Never shying away from a challenge, I went for it.
All of you that have posted above come from your own personal perspective based on experience. Mine is different.
I already had a leg up, so to speak, as the Lance Lite has tinky little holding tanks: 18 G. fresh; 11 G. Gray; 12 G. Black. This is a good weight-savings if going off-road and we can go, unrefilled/undumped for 5 days (with our Honda 2K genset). More if we pour the dishwater outside and take fewer or shorter showers: even more if we use our portable shower enclosure (it's like a tall, narrow tent) and put the outside shower water on the ground. The only thing we cannot do is extend the number of days of the black water tank. When it starts to come up thru the shower drain, you come to the knowledge that it's non-negotiable.
I set out to:
1. Stabilize the truck to haul the load.
2. Get movable heavy stuff down low.
3. Reduce the weight and bulk of what you take in the camper.
4. Increase the amount of recovery equipment you take. It's O.K.; weight is down low. Once you've been to the frame in this 10,000 pound beast you'll know why.
I did want to add that I have anti-sway bars all around, a power loc rear diff, and an after market power steering brace. When I first got my camper I thought I had made a big mistake since it swayed and wobbled all over the trail. After many suspension upgrades, like Rancho 9K's rr, non-adjustable shocks up front, that problem is gone. I now 'play' with the air pressure when off-road, just like jeepers, running differing lower pressures depending on the surface. This saved us over and over in places like the endless rocks and sand of Death Valley. I would say the three principal failure points folks who have tried to off-road their campers and wound up pulling it apart are;
1. Failure to fine tune (and have adjustability) the suspension's ability to take the load smoothly over any terrain.
2. Failure to adjust the tie downs to the requirements of the current terra firma and the torquing of the bed/frame.
3. too much weight up high. air cond., stuff loaded on the roof, heavy stuff inside the camper stored too high.
The case: I have a good friend who off-roads his hard side. He has the right truck, the right sized small, lite camper, BUT he has a large roof mounted AC, a couple extra propane bottles, a couple large plastic containers with heavy stuff in them like firewood, all 11 feet up. He has pulled all four of his eye bolts through their moorings on the camper box, and it's only a couple years old. A shame.
Another thing I've found is to 'go with the flow' when off-road. In a lot of ways, 'resistance is futile' so I keep things looser, even disconnecting one side of the rr anti-sway bar. I find I get more sway, off-road with the sway bar connected than not, just like the jeepers have found. Connected, if the wheel falls in a hole, it tries to pull the whole rig down into that hole with it. Disconnected is also good as it transmits the torque to the suspension and less to the frame. No air bags. Air bags along with coil springs tend to have an unrelenting problem: recoil or rebound. Even if heavily shock controlled, and I have a used set of air bags I'll give you, there is no getting away from the recoil. (The, "Boinga, boinga, oinga of life") Big, dumb, heavy, clumsy, rusty old leaf springs with all their built in friction are the best for a big heavy rig. They hit a bump, barely respond, and just say, "Huh, what happened?" I've also installed Stable Loads to engage the secondaries sooner. I must say, they really do stabilize the load, one of the few things I've ever bought that worked 'as advertised'. My camper guides keep the box from sliding sideways on the rubber matt transfering the tipping torque sheer down low.
About the only thing I need to do now is to fashion a 3" strap connecting the front bulkhead of the truck bed around the camper to the other side as a 'slide out keeper' like a limiting strap for going up steep grades (so the camper doesn't "slide out the back.....jack").
In the end, a built-up, for off-road, hard side truck camper may not be for you. But, I have stayed at it and molified most of the shortcomings down to an acceptable level. It's similar to the old addage: "Jeeps are not bought, they are built". The good part is: I have incrementally paid for all this; it's all paid for; and works like I thought it would.
regards, as always, jefe
bob91yj
I understand the limitations of my set up. I'm somewhat amused that you throw a "doom" prediction on my arrangement based solely on the roof air, yet you have 3' more camper sticking up in the air when my roof is down and 800 pounds give/take.
A little thought went into the roof air addition. The roof of this camper is designed for a roof air...in 2001 when roof air units were heavier. Being designed for a mini truck, the roof is smaller/flexes less than a full size truck model camper would. The Coleman Mach unit I installed is smaller/lighter than most, designed for a pop up. It runs on a Honda 2Kw generator. Is there potential for the roof air to cause premature roof failure...you bet there is! Is it worth the risk for my use...you bet there is! We live in SoCal, not unusual for us to be in 100*+ temps now and again. I'm getting old, my doc says I'm fat, roof air isn't nice to have it's required!
jefe4x4
Bob,
You are right; i don't know how much sway you get out of having an AC on top of a pop up. I thought your assessment was right on. My little Lance is about 15" taller than an Apex 8 in the down position. Most of that weight is air and lighter than the metal sissor hardware in the sides and roof of an Apex. My brother has the Apex and he likes it. I like it. I noticed your sig file. Hmmm?
In fact, Fat City was the one who built his rock racer a few years ago. It's still my favorite rock racing rig my bro (John Reynolds aka: JR on the Pirate page.) I use my CJ8 as a chase rig for him on occasion and was actually his spotter on the 1999 Warn Rock Crawling Championship at the Hammers. It is loaded with every eventuality (like the interior pic of your camper) including another spare, parts, 25 lb.CO2 tank, and an on-board, high frequency welder. I like your stretch unlimited. It is the new classic in the Scrambler heritage.
It seems we've trod a lot of the same trails.
regards, as always, jeff reynolds
Redline
Redline,
Yep, I knew is would make your case, that's why I posted it, as a good example. That long, old Ford flexes much more than my newer Tundra or other newer trucks, but the issue is still there.
I live in the same town and have talked to Gary and Monika Wescott (Turtle Expedition) and followed their exploits for the last 35 years. They may be the original Expo camper people. They have tried every version of campers from hard sides to pop ups and now use a frame mounted, 3 point attachment system on their custom made camper box. Since it's frame mounted you could not call it a truck camper anymore. If the box was removed there would be no 'pickup' use of the truck. It is one sweet purpose built rig. snip...
Yep, some of us also know the Wescotts, and you are correct about their experience and their rigs. :)
Though I currently have air springs on two of my 4WDs (not the F350), I agree with your assessment, spring rebound is a problem. I've also experienced the same issue on an off-road trailer, and the issue is exactly the same. The positive is the variable spring rate, but the suspension action does leave something to be desired.
James
bob91yj
How much air are you guys running? I don't run my truck that hard, but haven't noticed any real issues with the bags.
I added air bags to my Dmax a year or so ago. I use independent lines to each side. For lack of any better ideas, I usually air the bag up until I'm just off the overload spring, usually 30 +/- psi. Pressures do vary side to side depending on load. So far this has worked pretty well for me/my use. I'm not so concerned with articulation as I am getting down a dirt road to get to a base camp. Currently running Bilstein 5100's, intend to switch to Fox 2.0's one of these days. Biggest reason I'm switching to Fox is I know a guy that can tune them for me.
GM's front suspension is as much about the bumpstops that they ride on as it is the torsion bars/shocks IMO. Cognito steering corection kit/Bilstein 5100's are the only mod on the 's front end other than the RCD lift, which was a mistake, bought it that way. I carry spare tie rod/TRE/hub bearing and an axle shaft (flange to flange), fortunately those parts are all interchangeable side to side.
bloodyWEST
bob91 are you heading down to the B1k this year? i'll be dragging my 97 dodge down to LaPaz.
are your air bags long travel or standard?
i think i have decided against taking my hard side camper down there. just too big/heavy, seems you are always in a hurry while chasing and i don't want to be that limited. i am looking for a camper shell for this specific baja trip.
saltamontes
interface between truck and camper important
w/ a TC, the interface between truck and camper is very important (as many here have explained).
for example, be careful of the front bumper of the camper as the typical small stock rubber bumpers spread load over a very small area and can dent the front of the truck bed.
also look out for where the TC can impact the bed rail when the camper's bumpers compress too much.
make sure the cabover has 2-3" of clearance otherwise you will hear the TC "tapping" your roof on occasion.
the sliding of the TC is greatly mitigated w/ a rubber mat, but expect that the wheel wells can be impacted by the camper.
make sure to affix some heavy gauge stainless or aluminum to the TC and truck at these impacts points with plenty of high durometer rubber.
torklift frame mounted tie-downs are great and although their overload perch extensions work well, the design can be improved.
we have a f350 4x4 short bed SRW, leveling kit w/ king 2.5 shocks and airbags (max 20psi) and have bombed our northern lite 8-11q down many of the same roads mentioned by jefe above and besides some cupboards opening once in a while, the TC has had zero issues.
ReadyMedics
I ran a f250 up until last wk. Topper with full rack system and pre runner bar pulling a off road camper. I loved it but Life changes and I bought a FJ cruiser to wheel and a custom Class C thats 4wd for the family trips. Im just south of you and both are for sale so if your interested shoot me an email.
I loved wheeling it but the long wheel base is a factor. I opted for the trailer as it avoided the height and center of ballance issues and I didnt have to take "my house " with me on trail. i think the 250 is a great truck if you dont mind the limitations of their size. Rob
jefe4x4
I thought of a couple more things that I do to make the truck camper work off-road. Firstly, I remove the four corner hand crank screw jacks once the camper is on. I only use the jacks to install and remove the camper from the bed. It's only 130 lbs. of jacks, but I tried leaving them on once and found I scraped on a rock (I don't think I bent it, but that jack is much stiffer cranking now than before) and found I got considerable more sway, side to side than without. The jacks extend up higher on the sides and I think that contributes to raising the center of gravity. Plus, they're kind of like outriggers, swaying back and forth. Secondly, I come from a rock crawling background, (my CJ8's low/low is 130:1) not a desert racing background, so I drive only as fast as the conditions will merit. To a desert racer this is way too slow. Perspective is everything.
I'm reminded of driving into Saline Valley from the south on endless rocky, washboard with Rick 4X4X4 (he has 4 wheel steering on his GM truck camper). It was bone jarring. After a short time we stopped and I aired down: 30 lbs. front, and 28 lbs. rear (on those super singles). We drove on at about 20 mph and knew that wouldn't work. Not enough air was removed, so we stopped again and I lowered the pressure to: 22 lbs. front, and 20 lbs. rear. That was the ticket. The lowered pressure helped the rigs 'float' on the sand/rocks of the road and the tires became part of the suspension, not unlike what jeepers do. It was clear sailing after that with that pesky washboarding only a memory. You must take care to watch for overheating of the tires, but we had no problems. Modern tires are not problematic and a far cry from the 7:00 x 16 rayon bias ply NDCC tires on my first 4WD expowagon, a 1949 Willys Ute Wagon.
It was nice to be on the same page with Saltamontes. I've followed his 'stuff' for years.
Rob, Tell me more about your class Cx4x4 you have. PM me if this is too much hijacking for you.
Here Rick and I are north of the hot springs in Saline Valley, Death Valley. Rick is way down that endless road somewhere:if you squint, you can see his dust about center pic.
Here's Rick's 4x4x4 on a long sandy stretch in Death Valley-just the kind of roads you'll see in Baja, no?
bob91yj
What load range are your tires? I'm using my truck to chase the 1000 again this year, going to be pounding down the road to Coco's Corner again...this year I'm airing down. I ran a graded road with some recent rains a few weeks ago, aired the tires down to 35, felt real stable, not too much sidewall roll (315/75/16's) so I have plenty of sidewall to roll! Good to know that you took yours down into the low 20's.
Redline
I added air bags to my Dmax a year or so ago. I use independent lines to each side. For lack of any better ideas, I usually air the bag up until I'm just off the overload spring, usually 30 +/- psi. Pressures do vary side to side depending on load. So far this has worked pretty well for me/my use. I'm not so concerned with articulation as I am getting down a dirt road to get to a base camp. snip...
Yes, independent air lines.
Air spring psi varies from the minimum when unloaded to the maximum for a maximum load. I typically choose my pressure based on ride/control and ride height. How the truck drives and ‘handles’ can be very telling.
jefe4x4
Bob,
My rear high floatation 33x15.50-R16's on 12" wide rims can take letting more air out than my front 285-75R16's. That's why the difference in pressure. The fronts are E rated at 3450 lbs. The rears are E rated at 3750 lbs. They are pretty stiff, compared to wide sand tires I've had. I have run them for hours at 22 lbs., just like I do with my jeep's 37x13.50' XTerrains, except the jeep is much lighter so I can run on rough roads @ 10 lbs. of air for hours. In sand the jeep tires drop to 6-7 lbs. and sometimes down to 5, like at Pismo. Here's a comparo between the size on the front single and the rear duplex, both unmounted:
For you, as a starting point on the sandy loam and rocky travails of Baja, going about 30-35 mph, I would take a stab at: 26-28 lbs., depending on how much sidewall deflection you get. Basically the faster you go, the higher air pressure is needed in the tires, for lots of reasons. Disconnect one side rr anti-sway bar. Adjustable shocks on stiffest setting. My guess is that your lift kit has a stiffer spring rate than a stock setup which does not exactly give you much flex or a leg up, so you could lighten up on the shock setting to compensate. It's ALL trial and error. Except you won't have much time in a chase truck to fiddle around.
