Grandpa Builds A 2000 Montero
If I remember correctly, I spent about $700 on parts, primarily because I tried my best to purchase only parts made in Japan.
Good job Grandpa for getting it done and base-lining the truck!
grandpa
Exellent, thanks for the details. What is the interval for the engine maintenence you performed? 60,000 miles?
The timing belt is every 60,000 miles. I purchased the 2000 with 192,000 miles and the previous owner only remembered having it replaced once. At least now I know it's up to date.
philjherman
Hello!
Hey Nice Montero!
I hope you guys are still around since when this was posted!
I have the exact same montero (tan instead of white), did you adjust the torsion bars to put on the 33's or did they fit without doing anything?
grandpa
Thanks for the comments. I didn't adjust the torsion bars, the suspension is all stock. The 33's fit fine.
grandpa
Well look here..........a locking rear axle. :luxhello:
grandpa
It came out of a 1999 with 4.27 gears that matches mine. I'm going to start looking for 4.6 gears and see if I can find them for front and rear. I'll install it with stock gearing for now.
grandpa
ARB Compressor Install
I have given up on locating a factory air pump for the rear locker. I purchased an ARB compressor for an on board air supply and for the rear locker and a future front locker. I found that I could relocate the cruise control and mount the compressor on an extended bracket.
Here is the factory cruise control bracket with the cruise control moved out of the way.
I made a bracket that captures the rear of the compressor mount since the rear bolts can't be accessed once the compressor is in place.
The extended bracket mounted with the compressor in place.
The completed compressor installed with the cruise control relocated.
The included wiring harness made the connections easy. I'm waiting on a switch panel to mount the switches. Next will be the air pressure regulator and the locker install.
zukrider
what do you plan to do to regulate the pressure to the rear locker? arb's run 90 ish psi. yours runs around 9 psi i believe.
off-roader
Did you try searching on car-part.com for the locker compressor? There are lots of lockers being sold and everyone has the compressor...
grandpa
I have an air pressure regulator that I will use when I install the locker.
I did a lot of searches and phone calls, but couldn't find the factory compressor. With the ARB compressor I will also be able to inflate tires and install a future front locker. I'm happy with the results.
grandpa
Time for an update.
I got the rear locker installed and everything is working as planned. One of the good things is that the rear can be locked in 2 or 4 wheel drive.
I used ARB switches for the compressor and locker.
The factory locker only requires about 7psi so I used a pressure regulator.
sunnyaz
