Sliders, Swaybar Cables, Rear Bumpstops
I had the sliders done over the weekend and i am pretty unimpressed. The end result is a solid slider that will serve its purpose as a slider. The installation is a pure nightmare! The JCR instructions are very vague as to exact placement of the sliders so you are left to your own judgement. The unibody tie ins are secured to the unibody with self tapers (not impressed). Attempting to align all the holes perfectly after having to remove and install the sliders 3+ times per the instructions leaves you with misaligned holes and a generally horrible time trying to get everything together. The nutserts in the rocker serve no structural purpose as while installing them the torque of the wrench when crushing the insert will fold the sheet metal with no problem leaving crooked nutserts. I also noted some improperly spaced holes on the mounting brackets during install (the holes JCR makes).
The end product will serve its purpose as a slider and the welds are good. But i DO NOT RECOMMEND these sliders due to the horrible installation procedure.
Now im sure someone will ask if i was just cutting corners, nope i folwed the directions to the letter and still had issues. The removing and re installing of the sliders really gets it all out of whack. Im no professional but this is not my first slider install and this slider is far to complicated.
I had my buddy bounce on the slider and you can feel the slider wiggle just a tiny bit against the rocker, thus i believe a vertical pressure (sliding on a rock) will move them slightly but i foresee no failure of any kind. (i would no use these to bash hard or smash onto rocks though).
I will post more pics tommorow.
Sway Bar Cables. Too easy. Drill a hole in the bottom of the battery tray and attach, use one of the factory airbox holes and attach through into the airbox,(requires opening the airbox). They work great to hold those disconnects up!
Rear bumpstops. I got 4.1" bumpstops off of the quadratec website and ordered some nutserts from amazon as all of my bumpstop bolts snapped upon removal of the rotted bumpstops. Use a air hammer to break off the weld nuts inside the unibody and drill the remaing hole to fit the nutsert and crush the nutsert inside. Too easy. I can post a full writeup on this if anyone is interested!
