LR partners with Bowler to produce rally-raid models
Oilworker
And finally the very first Bowler EXR-S is ready, too.
It was actually finished late November and then presented to Land Rover, the customer, before christmas in December.
(Images courtesy of Bowler Motorsport / I appologize for the speckles in some of the images)
All you need now is a FIA Spec, flame resistant, Tuxedo and of you go!
550bhp, pretty lightweight and FIA Spec cage....I can´t wait to take that car up the Avenue Spelugues to the Casino :drool:
David Harris
Hay Haven, wasn't the Wildcat based off the Defender, Not the Disco???
I think the original Bowlers were Defender based, but then at that time all the Rovers shared the same basic chassis and drivetrain. Later ones definitely use the Disco II axles because they were wider and stronger than the Defender/RR/Disco ones. As far as the rest, it is probably a combination of different Rover and aftermarket parts.
SteveMfr
Supporting Sponsor
Axles? As in 'live'?
Methinks not...
Suspension – EXR
The EXR rally car uses fully independent suspension with geometry that has been designed and modeled to give specific competition handling characteristics. Combining the low centre of gravity, wide track and long wheelbase produces exceptional stability and driver comfort at all speeds, over all terrain.
The EXR rally has 3-way adjustable Donerre dampers, which include their patented fast rebound system, and hydraulic droop and bump stops. These dampers feature remote reservoirs that are positioned to benefit from cool air supplied by the bonnet ventures and side scoops, thus ensuring constant and reliable performance even in desert racing conditions.
http://www.bowlermotorsport.com/wp-content/uploads/2012/05/EXR_PDF.pdf
David Harris
Axles? As in 'live'? Methinks not...
Suspension – EXR
Right, not the latest which as you say are based on the latest Rover designs. Rovers have been successful rally contenders going all the way back to the Paris-Dakar winning Mark I Range Rover.
Oilworker
Well, it all started with an old 86" Series I, Drew and his brother found on the farm (where he´s build all cars ever since) and took racing.
A blacksmith by profession he mainly made these products before he started racing or, more precise, before he started building rally cars
The company started 1984 and it was soon after that they build the first customer car.
Drew, always pushing hard and trying to innovate with the products that were available to him, build the first ARC-spec car, combining Land Rover and Range Rover bits, thus creating the first coil sprung Land Rover (!)
1985 - Comp Safari (UK)
1986 - Customer Comp Safari car
1986 - Drew Bowler
2012 - The Bowler Story (from rear to front: EXR - Nemesis - Wildcat - Tomcat)
2012 - Drew Bowler with the very first EXR
Want any more images from the archives?
A great reportage about the Bowler history was published in Land Rover Monthly (December 2012).
Lockwoodjd
