Sankey Tent Trailer
Arlo
This is what you get:
a little bit corrosion here ...
... and there.
It'll take some hours to get it shiny! :wavey:
But let's have a look step by step.
When the bed is off the frame you'll first have a chance to calculate what you get.
The bed is something for the yard junky (it's made of corrosive steel, welded from sheet, havey... I don't like it)!
This is what you'll get back after sandblasting after all the parts had come apart hopeful :Wow1::
:ylsmoke:
It's always great to have a second trailer to get the new parts of the body and others zinc plated!
Assembling is just fun!
At last there was the procedure with the license plate... I guess these very special guys are spreaded out all over the world, aren'd they?
But I've got it! :victory:
tbc
Nightfire
I'm just starting my disk braked Mk3 rebuild. Your's is the first I have seen with a Galv chassis! Looks great! I'm doing the same to mine, although many have advised me not to bother because they are so thick they never rust through on the chassis.
Initially I am going to speedline the inside of the tub, the inside of the wheel arches and underside, then colour code the rest of the tub exterior in Epsom Green to match my Defender.
My hubs are being modified to allow matching EvoCorse Dakar whels to be fitted, also to match the Defender.
What is the machined part you post a picture of above as I can't see it on your trailer? Hub cover, Brake reservoir cover maybe?
Arlo
Hi, this is just a tool to bend out the bore inside the sheet for the side lamps in front of the trailer.
Getting the wide track chassis galvanized needs some big bores to let the fluids in and the air out of the tubes.
Kurt
Arlo
Modifications at chassis, handbrake, hubs a.s.o.
cranked handbrake lever
modified oilcatcher
tool to center the oil catcher
new hub caps
4th supporting leg
brushogger
Wow! Arlo you do amazing work. That thing is an expo-castle. I like this! I like this! I like this! I had a friend while growing up whose grandfather was a machinist in Germany pre-WWII. He said during his apprenticeship, they were given a block of iron about 1/2" oversize, and a file. He had to "machine" it down with the file to the required dimensions with no more than .005" error on all sides. German precision is tough to beat.
Arlo
Well, my block wasn't that much oversized during the education but my tool was a file too.
That happend long ago and far away in the late 60se of the last century.
We just call it: Stahl erzieht! (Steel educates)
But I'm not quite sure about this translation, so I'll send you the longer version:
... "to bring somebody up to be a fine, upstanding person" :wings:
Nevertheless, you're welcome! :friday:
Kurt
Nightfire
I doubt any German engineer would entertain any challenge where the measurements or tolerances where in inches!!
I had to do the same as an apprentice piece in 1998, teaches discipline apparently. If you took off too much material you had to start again...you don't do that twice!
Arlo
Hi,
this is the standart Nato-hitch which is used on all military vehicles with a draught-eye.
The claw is able to rotate full 360° in case of the draught-eye is fixed.
Otherwise the claw can be fixed if the draught-eye is able to rotate in its housing.
Kurt
xander69
