Electronic Ratio Adapter install pics?
Gonejpn2
Does anyone have any pictures of their Electronic Ratio Adapter install? What color VSS wire did you tap into? Where did you mount your box? Thanks!
ujoint
Supporting Sponsor
I always mount the box to the metal panel under the steering wheel. Wire color varies, but its usually black/gray.
Gonejpn2
Thanks Chris. I got it installed and it didn't do anything. I was hoping to see someone else's install to see if I messed up, lol. I tapped into the wire that was gray with a maroon stripe. The other wire is yellow with a blue stripe. Could I have tapped into the wrong one? I know I have power to the box because the little red light inside is flashing...
Dan
Gonejpn2
Thanks for taking the time to help me out today Chris! Turns out I had tapped into the wrong wire. It ended up being the Blue/Yellow wire. Working like it should be now! Thanks again! :smiley_drive:
nely
When it is tapped in under the dash, does it modify the signal b4 it gets to the cruise, abs, etc. Or does it only modify the signal into the cluster?
ujoint
Supporting Sponsor
Its tapped in @ the VSS sensor, so before any of that. Under the dash is just where the unit is mounted.
Lockwoodjd
