hdemetrious
Looking good. Why did you use two different types of solar panels? And you never answered the question about the 8 volts reading.
Does your battery monitor individually monitor things or you just mean as you individually initiate things you can see the results on the monitor? If the former remind me what you're using again?
I got concerned for a second thinking about how hot those unisolar's might get on your composite roof but then recalled you have an air gap between. I was tempted to grab some of those for my build when they went on closeout but I held off as I was worried about heat/delamination of my roof. I'm just going to use a standard panel with ~1" air gap under.
Okay here is a test.
I found this wiring diagram on how to most efficiently connect four batteries together to have equal charge and draw for all four, I found this diagram here; http://www.smartgauge.co.uk/batt_con.html
Seemed like a good idea so I did exactly as it was shown. Now after I wired it up I put my tester on the positive and negative wires coming out of the bank and read around 8 volts?? So what is up?
Pretty easy answer but I will post it tomorrow if no one gets it.
There is only one way that I know of to wire up four six volt and that is series and parallel with equal length wire runs.
Right on, I've got an inline doc wattson meter with powerpole ends that I was planning to use/move around to monitor things as desired. Just wanted to know if you want something cool that monitored individual circuits as part of a distribution panel or such.
Did you pick up your unisolars when they were on closeout? They were something like $90-100 for the 68watt at that point which is what tempted me. ATW? My concern about right on my camper is the black solar panel I would suspect would get hot and as you've learned yourself too much heat on composites can cause delamination. Thus I just picked up a standard 100watt panel when they were priced at $135. I plan to use a morningstar gen 3 sunsaver. Its PWM so not as efficent at MPPT but its way more affordable and the gen 3 does have stage charging verse other PWM controllers.
$.64/watt is for larger panels usually 24V. The 12V rv sized stuff is down as well but its more like $1.4/watt range for something like a 100watt panel.
Super sick!
