wiring lights on the front of my roof rack
dino2000
Any help here would be appreciated. Don't really know which way to go............down one side in front or all the way to the back.
Thanks in advance,
Dino
sydneyman
ive got a safari rack on my p38 and have wondered the same thing in case i ever pull the trigger on some lights... my plan was to run them along the bottom on the driver's side to the rear hatch and just have them enter either through the weather proofing or just between the weatherproofing and hatch...
ranewman
I was stuck with the same issue on my Disco. The best way I found was to install a snorkle. It not only helps you dress the wires to the rack, but keeps them out of harms way when wheeling....just my 2 c.
sydneyman
try to go wih the flow and not against it? :)
can you mask the wire or make it look good?
probably not! lol. my thought was just zip tie to the rack in some black plastic wire loom... i wouldn't want anything too permanent in case i needed to track down a fault or remove the rack...
achampagne
When I did my Disco lights, I ran them inside a plastic loom, and down the passenger side A-pillar to the cowl.
Like This: (sorry this is the best pic I have)
attachment.php
dhuss
