The GrassCat needs a new home
loremordred
It is truly a beautiful machine. After all the other Montys I have seen and driven.... GrassCat's monty purrs like a kitten. It is so well cared for, I am spoiled. Thanks GrassCat. Hopefully we can organize a trail run some day and Get the Forum together.
Your plates should be on their way soon.
Toasty
Ah, Well for anyone else looking to flat tow an automatic Gen 2 consider a cable actuated driveshaft disconnect and manual hubs up front. Mount the driveline disco on the transfercase rear output housing instead of on the diff (for four wheeling reasons).
Toasty
There was a Az snowbird who had one on his raider, we used to see him every year but i haven't seen him in a while. He wasn't into rockcrawling or anything but the truck saw some good use and he was proud of the disconnect so it probably wasn't giving him problems. I think it would get ruined on rocks mounted to the diff if you went rock crawling, imagine bashing a diff on an obstical and it causing your driveshaft to free spin. I think it could be mounted topside though, do the aussie slipyoke trick and then have the driveshaft shop install the disconnect with a slip shaft as well.
With more people building expo campers this might be something to look at, I'm planning on building a Fuso camper and towing my diesel behind it but i'll be all cheap and just remove the rear driveshaft and plug the rear output (take a gear oil bath every time)
GrassCat
T
Just tie the drive shaft up after removable, no oil bath that way. The disconnect sounds promising for a future project.
