Repeaters and routes/maps
Adventure IQ
Mtn Mike
There're many sites out there with repeater maps. This site has what you're looking for; a route planner: http://www.repeaterbook.com/repeaters/travel.php . More often I use repeaterbook's droid app: It searches for and maps repeaters based on your exact location. It's free and works well. But it's hard to use in advance if you're planning a route.
Mike
1911
Here's what I use, TravelPlus for Repeaters by the ARRL: http://www.arrl.org/shop/TravelPlus-for-Repeaters-CD-ROM
It's a map-based program/database; you can draw any route you want, specify a search radius, and it will compile a table/spreadsheet of all the repeaters with their offsets and PL tones that can be loaded directly into most radio's programming software.
Offtrack
Offtrack Traveler
Also if you have 2 way APRS many repeater systems due put out a local area beacon on APRS. (not all do)
If your in range of a repeater you will see it on your APRS station list. Kind of like Ham radar. This is a local only beacon and normally is not passed on by the APRS digipeaters.
I have a repeater system and the local object beacon is sent out every 15 or 20 minutes, if seen on the APRS station list you can for sure work my repeater system.
http://www.josephoregonweather.com/repeater.html
Scott KB7DZR
iStan814
