Lets see your full size Chevy!!!
highdesertranger
thanks guys, no build thread. when i built it i didn't even know about forums and such. built from scratch, built from the frame up. when it first hit the road it was seven different colors. now military desert sand and needs a repaint. quick run down. 30 gallons water, small oxy/act tanks, reddie mig welder, 1200 watt inverter, 4 batteries, crew cab with sleeper, 4spd trans, 205 transfer, 454 motor, 14 bolt dually rear end(the narrow one), dana 60 frt, bfg 235/85/16 mt, super lift 3 1/2 inch lift, 2 spares, warn winch, York on board air, 15 watt solar mounted, 210 watts portable, and more. if you guys want more pics i will post. this sunday june 30, i will be leaving so kal for 2 months, Oregon then Nevada. mucho overlanding. so will have limited internet. o did i mention it will climb a power pole or knock it down. highdesertranger
Larry
Bigassgas Explorer
My pair of old fullsize Chebbies built to play in the dirt :safari-rig:
Not a true build thread (been a project for the past 17 years) but it is a thread on the truck.
Build thread for the Polar Bear Burb
And a pair of newer ones that never see dirt :smiley_drive:
1leglance
Here is mine the day I bought it and did 130 miles of dirt to bring it home...
it looks a bit different now but this is still one of the best moments
gp01
