Say Hello to Garth - 1973 Series III
flipstah
Leaks.
Hi,
My name is Don and I've always had a soft spot for Land Rover's, mostly the Defender. When I first saw one in action, I knew I had to get one but when I found out Defender prices, the interest died down.
It was still there but not as pronounced until recently.
I was browsing around, searching random ads and here it was, not a Defender, but a Land Rover nonetheless.
For 40 years old, it was 85k miles so that's pretty good so I definitely had to check it out and see.
Did the appropriate research and found that these have aluminum panels and a steel chassis so that was my main thing to watch out for.
First saw it, it was awesome. No chassis rust, leaks like all Rover's do but not much, and runs rough because it's been sitting for a while.
He drove me around and bam, bought it after.
Plan to restore it enough to do some trails for now and we'll see where he takes me. I'd love to go on a long-term expedition with the LR but have to dependable first.
The former owner calls him 'Garth' so I'll continue the tradition.
So after buying Garth, I immediately got him insured and registered.
Insurance had trouble finding the car in the database and double-checked the short VIN but got it registered! She said to have fun because you're gonna need it. :rofl:
After that, it is off to safety inspection:
Other than few minor issues and the necessity of a new muffler, Garth is safe enough to be considered roadworthy. :thumbsup:
So in the back, it came with:
- Random bolts
- Rear seats
- Roll cage
- Soft top
- Tailgate
- Jack
- 40 years of random dust, dirt, crap, etc.
Man up!
Interior shots
Couldn't figure out this funk that the truck had and when I was vacuuming, I found it. It was a dead robin wedged in the seat.
After I got that out and aired it, no more stank!
The 2.25L petrol engine with a Weber carb and working electrics. SCORE.
Nothing like Spray Nine and WD40 to clean things up.
Installed the bench seats after and will make the left ones.
flipstah
Leaks.
So the truck right off the bat, runs rough. Idles rougher than a tractor engine should, felt like it didn't get enough air, and the timing was off.
So time for a tune-up!
Spark plugs make a BIG difference. FACT.
TRS (The Rover Shop) was closed so no oil change yet as I'd like to replace the gasket in the oilpan as well.
Cleaned the undercarriage with this stuff (also added Lucas Fuel Treatment in the tank):
The results speak for themselves:
Also bought an oilpan gasket, service manual, and upgraded coil/electronic ignition for a better spark. The Rover Shop Calgary recommended to do this mod to go with the oil change as a must-do modification to make life easier.
I also upgraded the horn to twins as the old one was pathetic. GTFO, bitches! :thumbsup:
On that note, hope my build thread will bring joy to people and possibly assistance when I need it, because I will.
Also, what have you noticed in my pictures that aren't original, other than the twin choke carb?
evilfij
Looks pretty original. You are missing the aluminium cover for the filler neck assembly. Rad cap is a replacement. Heater hose wiring looks cobbled together. Not sure what the little black thing by the washer bottle is. Can't tell from the pic, but does it have the fan shroud?
flipstah
Leaks.
The black thing by the washer bottle is actually the washer pump but doesn't work. May have to buy a new one.
No fan shroud; open fan.
Does it have a roof mounted licorice dispenser? Party on Garth!
-Jeff
Have you been hitting the wild turkey again Jeff?!
Looks like a solid truck, nice driver\project.
Haha thanks! With enough tweaking and a decent tune-up, Garth should be ready to hit the trails.
flipstah
Leaks.
So this is my first time maintaining a 4x4 so please, bear with me.
What are the fluids/gaskets that I have to change/bleed for a full tune-up? I have:
- 10W30 high-mileage oil, oil filter (has a modern mod!) and oilpan gasket
- Transmission fluid (not sure what gasket/seals)
- Brake fluid
- Differential oil?
Also, does anyone know how the handbrake works in this LR? I know it's not a brakepad handbrake but it doesn't really work right now so I put it on 1st or reverse, depending on the slope.
JackW
Hand brake is on the rear output of the transfer case - all mechanical linkage to actuate it. Lift the cover between the two front seats in the seat base and you can see the drum and cross bar linkage. The shoes are probably soaked with EP90 due to a leaking oil seal at the output shaft. There is an adjustment for the shoes but you need to remove the drum and check the linings on the shoes and make sure everything is clean before doing anything else.
The manual will walk you through the procedures.
Brake fluid - Castrol LMA only
Transmission/transfer case/differential fluid - EP90 (I like Valvoline) - there are seperate fill plugs for the transmission (left side of case) and transfer case (rear of case - about 10:00 to the rear output shaft).
Series trucks have a seal (usually failed) between the main gearbox and transfer case and a tendency to pump oil into the transfer case from the main gearbox.
Contractor
Nice looking truck.
I have a question for you.......in the below picture what does the switch above the fan motor switch do.....next to the headlights? Have you figured that out yet?
I have the exact configuration on my dash and cannot for the life of me figure out what that switch is supposed to do.
flipstah
Leaks.
Thanks for the help, everyone! Garth had an oil change last week while I'm in Japan right now. Just waiting for the muffler to arrive when I return.
Nice looking truck.
That switch turns on the instrument light and cabin lighting. First, the headlights have to be on (either daylight or lowbeam) then first flick is the cluster then the second flick down is the cabin lighting (for hardtop but mine isn't connected).
evilfij
Buy a fan shroud. You can't tell when it is overheating so you want the shroud even though you are so far north. Also, pull the brackets on the bottom front of the tub, clean them, paint them, and put rubber behind them lest the tub corrode out there. You don't seem to have rear side belt brackets which kills SIII tubs.
flipstah
Leaks.
Thanks for compliments, people! :)
As for the fan shroud, I'll definitely look for options when I return. Also, can you elaborate on the 'tub' and this bracket thinamajig you were mentioning?
V45W_Proto2.5
