What would you do
Nonimouse
Cynical old bastard
Loads of other things that will make it bang
the 4.0 is a 3.9 with one or two difference and the liners only slip if you drive it like a fool - we rarely get liner slip over here even at 250k plus unless it is a 4.2/4.6
The we chuck in a set of top hat liner and carry on
Hell we even get reliability on LPG so what are you guys doing?
rwhitmo04
I sourced a good used block and then gathered all the components to build up a 4.6 to put it in.
Did you build your 4.6 by using 4.6 internals (crank, pistons, cam) and a 4.0 block, or did you get a 4.6 short/long block?
Since you already have the 4.6 internals, you can pull your block and take the 4.6 internals along with a used 4.0 block to a machine shop. Get everything checked (unless you have the tools to do it yourself). If your block and pistons aren't worn out of tolerance, then you're in business. Build a 4.6 using the 4.0 and 4.6 internals. A 4.0 short block, or even a bare block, are not hard to come by. The machine shop might charge you around $100 to check everything.
upjeeper
take ur radiator out , go buy muriatic acid from pool supply store mix it with 20% of water , fill it up inside ur radiator , wait 5 min flash it out ,do it again , and u can have almost new condition radiator ,
whenn i got my old classic it was over heating like there is no tomorrow , it was bad radiator someone told me to do the same , and after that i was amazed how cool truck run,
first do the less expensive tests ,
radiator , fun clutch , pressure test, the the most important for the rover system, ( the tiny thin hose that goes from the radiator to expansion tank ) when thats blocked it will make ur truck to over heat ,
Eric
sorry to change topics, but do you run the motor at all to get the muratic acid throughout the cooling system or just in the radiator?
KyleT
Before you call it a liner, dump 1-2qts of ATF in the oil and run it a hundred miles or so then change it and put in 5/40 rotella t6 synthetic and drive it a couple hundred more to see if it was just a lifter that was bad or noisey from being clogged up,
tacr2man
if I lived in the states Id be looking at fitting a small block chev, or LS1/2 , dont know what the dollars would be on that tho ? JMHO
Ray_G
A lot more than putting a whole new Rover engine in...or building a better one, etc. Also a lot more than the truck is worth-IMHO.
Nonimouse
Cynical old bastard
Lets be honest here we might have the OE parts access, but in the US you guys have a better range of decent engine builders - if I had that sort of access to specialist machine shops I would be re-building the original lump
We know it works at up to 5.2 and is reliable, although it needs a re-worked P38 alloy sump.
Where I live in the UK we have one decent engine shop, and that's in the whole county
Henrybrowne
