I modified the stock rear bumper to hold water for washing not consumption (I would drink in emergency). It is great. I did mine a bit different than in the link above. I put a 1/2" plastic elbow (threaded on one side and barbed on the other) on each end of the bumper so water would be picked up no matter the angle of the jeep. I then threaded it into a hole i created on the bumper and sealed around it using Plumbers Goop. I then attached 1/2" clear line to the barbed end with a pipe clamp and ran it down the bumper mounting it with superglued zip tie mounting tabs to a barbed t union. Both lines run to t union and the bottom of the union is left open when not in use but prior to filling I pipe clamp a plastic cap to barbed output then fill bumper through hole on top that is seal with a rubber expanding pipe stopper. When I get to the camp site I take cap off of the T union and clamp on a 1/4 turn ball valve with approx 20" of hose that allows me to control water flow and wash up. Bumper is sealed so well I have to remember to vent the stopper to release the vacuum. Prior to leaving I simply reseal stopper and change the ball valve out for the plastic cap on the T union and off I go. I have used it approx 3 nights in a row and never ran out of water for hand washing and dish washing and I read somewhere it holds approx 7-9 gallons. I plan on testing the volume more accurately soon. I will post back when done with that. Hope this helps.
