For LR4, thinking of switching to LR3 18"s and have a TPMS question
Bhos
Will I need to replace TPMS sensors if I switch to LR3 18s? I know that if I go Compomotive, I will need to get TPMS sensors. Just trying to add up the costs, with new shoes, TPMS(?), spacers, wheels, etc.
Thanks,
Brian
Chris Cordes
Just a heads up with the 18" rim spaced out as required you'll rub a good deal during turns with a 33" tire. If you plan on being smaller than that you may be okay but our LR4 does rub occasionally when turning.
mcieplinski
Hi - I am also thinking of switching to 18in wheels (from 19in - I have 2011 LR4). Did you instal spacers to avoid rubbing ? Also did you have problems with HVAC lines at the rear wheels ?
Thanks a lot for your insight !
Bhos
I doubt I'll go bigger than a 32" tire, more like 31.5." BUUUT, I do wonder about the Cooper Zeon's in 19" that are available now. I have a line on some 18" wheels, but for the price of the 18s and spacers I could get the Gap Diagnostic tool and go with the Zeons. Advice?
umbertob
Don't forget about the new Goodyear Wrangler A/T Adventures that just came out. They are sized 255/60R19, so they have more usable sidewall than the Zeons while still fitting comfortably on an LR4. I realize Goodyear tires don't have a lot of fans out there, but their SilentArmors seem to be getting decent reviews among dual purpose pavement / dirt tires, and these Adventure A/Ts look very similar, at least in design. Be aware that the Coopers will get noisy over time (at least the 18" size.)
Bhos
Umberto, I need a guinea pig report first. Kevlar and similar to the SilentArmor are good things, though. Love your truck, btw!
Oh, I've about wore that thread out, getting burn-in on my screen :ylsmoke: I'll ping him, thanks.
I'm not sure on that as I wasnt here for the build but you might want to check this thread below and then if not PM Scott. He could answer that question
http://www.expeditionportal.com/for...-Journal-Project-Land-Rover-Discovery-4-(LR4)
Mike, have you heard of anyone using them yet?
psykokid
Unless you can find someplace that has a set of the compomotives in stock at present you my be SOL. IIRC they were made to order and it looks like they have just gone belly up... :(
Jagman
Was that the Compomotive rim manufacturers or a distributor?
DanoWall
