Lexus GX470 Expedition build
boo471
"custom" exhaust.
I have been looking at the stock exhaust. It hangs low and the end pipe goes out straight out of the back and I constantly hammer it with rocks. And you can barley hear the V8 in this thing. So I figured I would address that issue with adding a Flow master super 40 muffler and a customize the piping in the rear. As a plus it seems i got a little better throttle response as well.
I cut out the old muffler and rear pipes.
I welded on some new piping and mounted the new Flow master super 40 muffler.
Here you can see the new tail pipe. Sitting a lot higher and now exits right behind the rear wheel instead.
And this what it sounds like. Who knew that you can actually make this V8 roar.
boo471
Reverse lights and side lights added
I welded some additional tabs on my roof rack yesterday and mounted my reverse lights and side lights/off road lights. Turned out pretty good. Reverse lights give you a good view backwards and the side lights is good to have when driving on the trails night time or when camping. I already have a electrical harness wired up to my RTT ( I will show that in a later post) for LED lights in the tent and for USB charging and 12V power socket in the tent. I will add a second switch in the tent that will kick off all of these lights to use to scare of anyone or anything trying to sneak up on the truck while you are in the tent.
I will give you a few close up pictures on the set up when it's not pitch black outside.
The reverse lights are 2x 10W Cree LEDS. The 4 side lights are 2x 10W Cree LEDS and 2x 19W Cree LEDs.
Reverse and side lights on
Reverse/side lights and LED light bar on.
boo471
Random photos
Here are some random photos of the GX
She is resting at home after a day in Uwharrie
Out for a day trip with the Triad locals
Water crossings are about having enough speed.
Trying to figure out the best line without killing my front bumper.
The views weren't great this foggy day on old NC 105 but at least my ride looked cool.
boo471
Close up's on roof rack light set up
Here are some daylight photos on the new roof rack lights.
2x 19W LEDs on each side in the front.
4x 10W LEDs in the rear corners. 2 for reverse lights and the other 2 working with the front side lights.
boo471
Original build thread
My original build thread started at ih8mud.com. Feel free to go in there to read more about discussions that took place during the build.
ih8mud.com
boo471
I like the light set up on the rack. Nice work!
Nice work! Looks great.
Sent from my PC36100 using Tapatalk 2
Thanks. I'm pretty happy with it myself. It's pumping out tons of light now. So that feels good when out driving in the dark.
Dorton, I'm sourcing parts for my front bumper build and planning on starting that with in a month or so I hope. I'll keep you posted if you feel like helping out.
dorton
#rockcreekoverland
Let me know. I'd be more than happy to lend a hand.
boo471
The top of that hill on Dickey Bell does get a little tricky.
Actually most of the hill went fine. It was just this one ledge where I couldn't go straight on without mashing up my front bumper so I had to turn in to it and it got me with 2 wheels on the ground. And with open diffs that can be an issue. But other than that not to bad. It sure was fun!
boo471
Exhaust build continues.
I did the custom CAT back system of my truck get the exhaust tucked up under the truck close to the frame. Apparently I got it to close and maybe to short so the gases started to melt the rear bumper. So to day I welded on some more piping to get the exhaust tip nicely placed behind the rear wheel. Should still be good enough and not get hit by rocks and the rear bumper should also feel better about the new position.
boo471
Hitch receiver/recovry point.
So I was lacking a hitch receiver on my truck. The OEM bracket is like $160 and will make the departure angle reaaaaally bad. So I decided to by one from Harbor freight tools. Do a cut out in the rear cross member and weld it in place instead. This should be plenty strong enough and it will not effect the departure angle, or at least very little.
I started with removing the rear bumper
I was then able to remove the OEM mounting bracket for the Lexus hitch. And cut the cross member
I welded the receiver in place. And sprayed it with zinc primer. I also found some surface rust on the top of the cross member. So I removed it and spray it with zinc primer as well.
Then a couple of layers of satin black paint.
Taaadaaaa!
I had to do some cut outs in the rear bumper to be able to fit the receiver that far up but it looks pretty good.
///Marten
