Snatch block for 3/8" Synthetic?
fishEH
What snatch block are you guys running? I recently upgraded my winch line to 3/8" from 5/16". So I need a new snatch block that will accommodate 3/8" synthetic line.
LR Max
Local Oaf
Currently using an ARB snatch block. Works just fine. Used it the other day when doing monthly winch maintenance just for giggles. Haven't used it in anger in 5 years or so.
Antichrist
What snatch block have you been using that won't work with 3/8".
Even my nearly 40 year old Warn will, not that I'd use it with synthetic now since I've always run wire rope.
Eventhough
Either of the ARBs will work. I like the MasterPull block made specifically for synthetic. It is lighter and functions better with syn line. I have it right now in the shop recovery bag.
hoser
I like my ABR 9000 Ultra lite block but it's not really light at 5.5 lbs. Works for 1/4-1/2"
20k lb work load limit, 38.5k lb breaking strength.
I use it with my M12000 winch. I figured worse case scenario, double line pull would exert 24k lb of force. Logic might be off but that's how I decided.
zhukoveli
