Gitout Expedition Build - 2013 Toyota Tacoma DC TRD
montypower
Adventure Time!
Finally got some time to install the Icon 2.5" Resis Shocks and Custom Deaver Leaf Pack. Testing to follow soon...
Kodachrome
Wow, I had no idea Icon came out with those, I have the 2" versions on my rig that I got in 2008. They are holding up good enough but might need to be re-built because the rebound is starting to fade with the camper on the back full time. Also, mine have the rubber boots, is there not an option for those with their rear sets anymore?
montypower
Adventure Time!
I'm not sure if they sell boots for them or not. It probably wouldn't be a bad idea...
montypower
Adventure Time!
Why did you go with the Deaver opposed to the Dakars? I'm torn between the two for my setup.
Dakars are fantastic. I ran them with the additional leaf. They were good for about 400-500lbs of additional weight. Currently, I'm rolling with 900lbs everyday and an additional 400-600lbs on trips so I needed something custom that would handle the weight.
BenMara
Asian Redneck
If some one made a Plate to put a Larger battery on the Passenger side, id just go ONE battery. But too many Amp hungry toys i want to run, currently Ham equipment alone can hot 75 amps, just imagine if had an ARB cooler, and other junk....
montypower
Adventure Time!
I'll be replacing my tires soon... Does anyone have experience with the Cooper Discoverer ST Maxx? 3 ply sidewall. M+S rating. Similar to the Duratrac tread (at/mt mix). Plus, it comes in the 235/85 size! Measures 31.95" so almost a true 32". 18.5 tread depth.
