Moving the thread!
Well, I've decided to move my build thread over here to it's rightful home!
With summer coming up, I've got a bit of work to do, and hopefully get some trips in this summer amidst planning a wedding in August.
-please stand by-
So, first some info about these vans for those that don't get to see them around (south of the border).
It's a 1996 L400 Delica SpaceGear Exceed. Yes, that's a lot of titles, the L400 is the body style, Delica is the model, SpaceGear I think means that it's the 4x4 and Exceed is the trim level. The next levels are Super Exceed and Royal Exceed. The royal comes with a karaoke machine!! Both the super and royal have what's called 'crystal lite' roof which is twin sunroofs down the side of the van with power shades. I don't have that unfortunately but the van was in such good shape I couldn't pass it up.
A quick note about the 4x4 system in these. It has 'super-select' which is a locking centre diff. So I can put it in 4hi, 4hiLc or 4LoLc. The 4Hi is pretty much AWD, which is great on the highway when its snotty out, I don't have to lock the centre diff if it's not necessary, saves some wear and tear.
I bought it two years ago with 80,000km on it, since then I've driven across the country a few times, I just rolled over to 180,000km.... It's had an IP rebuild, NEW: injectors and glow plugs, battery, alternator, trans mounts, water pump, brakes, sway bar bushings and links all around, fuel filter housing, procomp shocks, tie rods, upper ball joints, cv boots a couple times, valve cover gasket, hmmmm... I think there's more. That's what happens when you put 100,000km on a 15 year old vehicle in a short period of time!
It has a 2.8L intercooled turbo diesel. I've deleted the EGR valve, it has full 2.5" stainless exhaust from the header through a small Magnaflow baffle. 2" lift with 31"x10.5" Duratracs on 15" Ultra Wheels, I also have Airlift air bags in the rear springs. I should have gone with 30" tires. I've trimmed as much as I think I can but it still will rub on compression in a turn. That being said, the 31s look awesome!! I've got a Uniden CB inside as well. The door speakers have been upgraded to some Alpine type E speakers. They're bottom of the line but the difference is amazing!!
On the To Do list: Bed line the roof (paint is turning crap), Bed line the grey part of the body (shredded from gravel), fender flares, upgrade all stereo, build drawers for the back, aux battery system, upgrade alternator, upgrade torsion bars, new roof rack fabbed, full underneath armour fabbed, re-tint windows, alarm and auto-start.
Here's a thread of our trip to Lab/Nfld a month ago via the Trans-Labrador highway -
http://www.expeditionportal.com/forum/t ... rador-Loop
IMG_0233 by
TheMacrobius, on Flickr
This it what it looked like when I first got it, before the suspension was totally gone!
IMG_4559 by
After the lift! 2" of lift via torsion crank and spacers in the front and stiffer springs with Airlift airbags in the back.  Procomp shocks all around.
IMG_4435 by
Here's what used to be in the back, a third row bench seat.  It was always up though because I need space for tools and material and whatnot, so I removed them and built..
IMG_4562 by
This!!  Bolted some Unistrut where the old seats were and voila, platform.  When we go camping I'll fold the seats flat and I have a platform extension that bolts on.  Next summer I'll build drawers and a cabinet for the back.  Something to keep it organized.
I'll try and keep this thread updated, I'll look through my pictures and see what else I've done to it and with it.  It's a slow work in progress because I live in an apartment, so any major work I have to drive 1.5hrs to my folks and use their shop, hope you enjoy it!
P8261736 by
IMG_2120 by
Here's some info on what I've done on the inside.
The third row of seats was always up and out of the way to make room for my tools, but you could still peer into the window and see what was back there so I wanted to build a platform to keep things hidden underneath and to load material on top of, or just to have a lunch table!
Before!
I built the side brackets out of Unistrut and bolted them where the seats were.  With the strut, if I ever want to make the shelf higher, to fit a fridge underneath maybe? All I have to do is cut longer legs.
It was  tight fit... The shelf is just 3/4" ply with outdoor carpet glued and stapled on.  I like it, makes it look pro I think!
3/8" Carriage bolts drilled through
Wingnut on the bottom
Tadaa!
Here you can kind of see our camping set up, I'll see if I have a better picture somewhere.
This was a pull out off the Trans-Lab just after Happy Valley/Goose Bay. It's only been there a couple years but there was already garbage everywhere as you can see by the A&W.  There were a couple squirrels around that cleaned those fries up in short order though.
