"ultimate" (modular) trail welder & jumper cable kit
theksmith
i thought i would cross post this from Offroad Passport since the trail welder concept has been discussed some over here:
i've been carrying around a set of heavy duty jumper cables as well as a custom battery trail welder setup for quite some time. there's really no need for both. after all, many people have done welding with just a couple sets of jumper cables.
old separate setups:
how about a little background...
to do some emergency trail welding, you just need good sized cable to connect the batteries from 2 or 3 rigs in series to get 24 to 36 Volts. as long as a couple people have heavy duty jumper cables and someone carries some welding rod, tinted goggles, and leather gloves - you're good to go.
a few of us have tried to make things easier to use and more efficient by creating a dedicated setup for trail welding. using large gauge cable with terminal clamps to make solid low-resistance connections and adding a proper rod holder and ground clamp, we have ourselves a "trail welder".
my goal was to merge my jumper cables and trail welder into a single "ultimate" setup.
one issue was that my batteries are hidden away beneath the floor in the rear of the Jeep due to my particular dual battery setup. so i have an Anderson SB175 connector under the hood to connect to for jump-starting instead of normal battery posts. that's why my old jumper cables in the picture above only have one traditional clamp end.
so requirement #1 for the ultimate setup was to work as jumper cables for my rig. here's the custom jumper cable configuration:
requirement #2 was to work as regular jumper cables if i need to loan them out while on a trail. here's that configuration (same as #1 but with additional clamps attached to the Anderson connector):
then requirement #3 was the trail welder setup. for that configuration, i just swap out the main positive clamp with the rod holder clamp via the single Anderson PP180 connector and use the extra 2 short jumpers to connect the multiple batteries together:
a few little tricks round out the kit...
i used rubber coated "parrot" style clamps everywhere since they are compact. these particular ones have dual copper contact areas. however only one of those contacts was designed to connect directly to a lead, and the other was making a poor (high resistance) connection to the clamp due to the rubber coating.
so i took each clamp apart by drilling out their hinge rivets and then i jumpered both of the copper contacts together with a short 6 gauge wire. they were put back together using 1.25" length screw posts for hinges.
i added a voltmeter to the main Anderson connector by making a small bracket out of aluminum. the idea behind this is that i can monitor the total voltage on a 2 or 3 battery set while welding to know when the batteries are getting so low that they might not start a rig anymore. after all, it would really suck if just a couple of us were out and completed a welding repair only to find that neither rig would then crank!
it also allows me to see what a person's "dead" battery is really at so i have an idea whether they just need a this one jump or if it's so far gone that they better drive directly to Autozone afterwards.
i used quick-clamp style terminal connectors on the short jumper leads. they are attached to a crimped ring terminal with a bolt. they don't look particularly robust, but i chose them because they make quick low-resistance connections. i have a couple extra of these connectors in the kit just in case one breaks.
all the cable is 4 gauge, which should be fine for the short use times this will see trailside.
instead of goggles, i butchered up a cheap welding helmet like this one:
i removed the front flip lens, putting the smoked glass directly into the main helmet window area. i also cut out much of the sides so it would be less bulky and the back could fold-in. doing this and storing the head-ring apart from the main shield allows it to all pack into my kit bag and squish in behind my back seat easily.
i bought some welding gloves from Harbor Freight to add to the kit as well. my current rod is 3/32" 6010, but i've yet to test it out personally so that may change.
everything fits in a 15" canvas bag, also from Harbor Freight, which tucks behind my back seat. it does indeed take up less space than the previous separate jumper cables and welder setup.
i should have some time this weekend or next to actually test the setup and see if anything needs to be modified.
i started a little instruction sheet to include in the kit (below). anyone have any suggestions for it or spot any mistakes?
Batteries / Voltage
12 Volts (12.8 actual) = 1 battery.
Difficult to strike an arc and poor penetration.
24 Volts (25.6 actual) = 2 batteries in series.
Good for general purpose use.
36 Volts (38.4 actual) = 3 batteries in series.
Easy to strike arc. Too hot for most areas on a vehicle, good for thicker materials like frame-rails. Could possibly be used for cutting.
Polarity
DC+ / Electrode Positive / "Reverse"
Deeper penetration, good for medium to thick material.
DC- / Electrode Negative / "Straight"
Shallower penetration, good for thin material.
Hook-up the battery clamps backwards.
Electrodes
6010 (DC+)
Extremely tight arc, difficult for beginners.
Deep penetration. Good for thick or dirty/rusty/painted materials.
Fast freeze. Good for upside-down, vertical, etc.
Could be used on thinner materials with DC- polarity.
High spatter, hard slag.
6011 (DC+ / AC)
Very similar to 6010 but works on AC too.
Compared to 6010, this is slightly less penetrating, has a slightly rougher arc, and has slightly more difficult-to-remove slag. However 6011 is easier to find at generic hardware stores than 6010.
6013 (DC+ / DC- / AC)
Smooth, easy to start arc, good for beginners.
Light to medium penetration. Use on clean metal. Good for sheet-metal and general purpose.
Low spatter, medium easy-to-remove slag, good appearance.
7014 (DC+ / DC- / AC)
Very easy to use, great for beginners.
Medium penetration. Best used on decently prepared materials.
High deposition which allows welding at higher rate of speed.
Not out-of-position friendly, use on flat surfaces mainly.
Moderate spatter, very heavy slag.
7018 (DC+ / AC for some brands)
Smooth arc, easy first strike, hard to re-strike.
Medium penetration. Best used only on well prepared materials.
High strength and versatile. Works on many materials (unknown type of steel, iron, etc.)
Minimal spatter, very easy to remove slag.
Important to store air-tight to keep from absorbing moisture from the air.
Kit Cheat Sheet
For the included 6010 3/32 electrode:
- Material less than 1/8" thick: 24V DC-
- Material 1/8" to 3/16" thick: 24V DC+
- Material greater than 3/16" thick: 36V DC+ or 24V DC+ multiple passes.
the complete thread is here: http://offroadpassport.com/forum/showthread.php?t=3114
i tested it and tried to learn some stick welding basics today, but found the 6010 rod is very difficult for a beginner! i then picked up some 7014 and 6013, and will try those later this week.
h4rdflip
That is cool, I just started to weld and I really like it, would deep cycle batteries work as well for this purpose if there not hooked up to the charging system. I learn this summer that they are really weak on cranking amp since it couldnt turn the old Chevy 400ci.
Dawgboy
Very nice! Where did you get the Anderson connectors and clamps?
Brought to you by Cyberdyne Systems
theksmith
my guess is a deep cycle would provide enough amperage, and would be better since it could deliver current longer without damaging the battery.
and no you don't want them hooked to the charging system for sure. you should remove the batteries from the vehicle to prevent any voltage spikes from getting to sensitive electronics.
i'm actually enjoying learning to stick weld. i went right to wire fed originally since it was easier, but i'm seeing that stick really is more versatile. you can get electrodes that will weld nearly anything, including aluminum. you can even get cutting/gouging electrodes that will work kind of like a torch. i was considering this little 100amp DC arc welder for $160: http://www.amazon.com/Hot-Max-ARC100-100-Welder/dp/B00440DVB2
matthewp
Combat Truck Monkey
Great thread! This really breaks it down. Thanks for the info... I'm off to build my own set-up now!
bfdiesel
I have always just used the jumper cables. If I am in a pinch and need to weld on the trail it works good enough and is not extra to carry. Welding helmet would be nice though. Look, memorize, look away, weld a little, stop, look, access, repeat is not ideal but can "git ur dun".
Stumpalump
I saw FrankZ borrow about 4 pair of sunglasses to make a long weld. He just put on all the shades at once and it was dark enough for him to weld. Fwiw from the times I have seen it done it takes three batteries unless it's really thin material.
OSV
I picked up a goweld portable mig welder, sears was blowing 'em out for $250 awhile back:
http://www.off-road.com/trucks-4x4/tech/broco-incs-goweldo-portable-mig-welder-21732.html
powering it with a couple of those odyssey rebadged agm batteries from sears, for less than $200 each, on sale.
this rig really puts out the heat, it completely blows away my cheapo 110v harbor freight stick welder... I suspect that 24v worth of car batteries has far more potential amperage on hand than anything that you'll be able to get out of a 110v wall outlet.
the downside is that I don't believe that you can use those round gas welding googles with mig(??), and the case for this particular unit is very bulky for dragging around on the trail... the readywelder unit would have been smaller.
I originally looked into setting the vehicle up for a switchable dual use 12/24 volt setup, but not many people are doing it, and it's rather complex to wire... what's needed for any of these welders is an Anderson connector on the outside of the rig that's wired for 24v, and a simple way to switch the dual batteries back to a 12v configuration for running down the road.
Xtm10
Hi, where did you find that volt meter ? ? I have a similar setup and would like to add it. Thanks !!
oskarf150
