Martinjmpr
Wiffleball Batter
I've been wanting to do a sleeping platform in the back of my 4runner for years but I'm having difficulty figuring out how to start. My woodworking skills are fairly basic, though I do have a table saw, a small band saw, a circular saw and the usual drills, dremel tools and a belt sander.
What I'm having difficulty with is figuring out how to make the platform work and still be fully removable. Obviously the top portion can be plywood, that's easy. The tough part is: how should I construct this? A full box with the plywood platform on top would be stronger, but would also weigh more. I will most likely figure on the outer edges of the platform resting on the fender wells but supporting it in the front is problematic because of the way the back of the back seat angles up, even when it's in the "down" position. Ideally I'd like to have something I can slide in and then slide back out when I don't need it, but obviously it's also got to be sturdy enough not to bounce itself to pieces when I'm on a rough or washboard road.
I'm sure others have had this problem and have come up with a solution. I'd like to hear what others did and how you did it. I hate reinventing the wheel and what I hate even more is working up some incredibly difficult and complex solution to a problem and then having someone else look at it and say "why didn't you do [much simpler and easier solution] instead?"
I would especially like to see how anyone has made a platform in a 4th gen 4runner.
Thanks in advance!
Thanks in advance!
