Who buildings custom camper boxes.
Cagiva
Guys, I'm looking to build a big 4x4 expedition camper. Can anyone give recommendations on who will building a custom box to be placed on the frame, here in the USA?
incognito
Hy,
if you are talking about a service box you can google truck body, utility box, body or service box or body. You have many manufacturers , Readings, Royal truck body( mine is a royal truck body 9 feet-had to cut the back of it to fit the camper). You could have them in steel ( 1100 Lbs mine), also aluminium and fiberglass. Also commercial truck trader sell used .
truck is heavier, but i have a lot of storage space, even more than i need. best modification i've did.had a good welder who helped me done the project.
good luck
pappawheely
Autonomous4X4
Who builds the sleeper boxes on the semi trucks? I've seen some very large ones that would be perfect for a camper.
mhiscox
Exp. Leader Emeritus
The longer sleepers are generally made 90" wide, with options as wide as 100" or so. Seems likely that would be too wide for most overlanding uses. There's also a gaping hole in the front end to walk through to the cab. Perhaps a company like Indiana Custom Trucks or Double Eagle might build a unit to spec, but their normal units likely wouldn't work.
I, for one, would like to have the names of companies building expedition-quality cabins in North America. While there are several European companies, the only companies I know of here have either converted less rugged dry van boxes or have built just a custom one-off for a client. If there's someone out there I could call up and say, "Here's your bag of money; build me a box 12 x 7 x 6.5," I sure don't know of them . . . and I'd like to.
fisher205
Check with Darrin Fink http://www.ruf-inc.com/. He told me he could get any cabin I needed built from his supplier for his campers when I was looking at building them. I don't know if he is still in the business, I haven't talked to him in a while.
seth.c96
