For Sale: Fiamma Room-Wall Kit for F45 2.6M Fiamma awning)
spressomon
SOLD!
Fiamma Wall kit for Fiamma F45 2.6m awning. Includes 3-screen/window walls (one with a "door"), poles, stakes, top rails and carry bag. For increased versatility each wall can be used separately (erect 1, 2 or all 3 walls). Shown set-up to the Fiamma awning (not included) mounted on my Land Cruiser.
I had it strapped to my roof rack apart of one trip but otherwise never used the wall kit in the field. The cordura type storage bag's coiled zipper slider is off-track...and a couple very small abrasion points as seen in the attached photos from hauling around on the roof rack...where the tie down straps abraded.
$200 (20 cents on the dollar!)
Pick up at/near Monterey CA area
Borrego60
Rendezvous Conspiracy
Does it seal the rain out? As does the rain slide off the side of the awning and down the inside of the sides.
spressomon
The side walls attach to the brackets that quickly snap onto the sides of the awning via a gunwale type system; ditto for the outer wall (with door). Although I have not tested it let alone in the rain I surmise you'd be very dry inside this shelter.
I thought, since selling the Kimberley Kamper, I would use it...but my travels are not such for camping more than one night in the same spot since the 'other half' decided she doesn't like camping after all.:rolleyes:
spressomon
Do you know if it works on the 35???
I doubt it would work very well...each of the two corner walls are attached to the outer wall/door panel via zippers that match up to each end of the awning...the 35, I presume, would be too short in width.
cellularsteve2
Are these only screen walls or is there opaque material to get total privacy? On the fiamma website the photos sow some sort of curtains on the inside. Not sure if that is optional or newer product if yours doesn't have. Thanks for clarification.
spressomon
This kit consists of screen walls and clear zipper "windows" over the screens. As you mentioned I believe there are curtains...I will check to be sure and get back with you later today/tomorrow at the latest. Sorry to be vague...just never used it.
