Land Rover Quiz
Close enough.
PN: 264590
Congrats. You win a brand new DC100.
Time to step it up.
What LR made non-rivet/bulb/screw type part number do a Series 1, Series 2, Series 3, Defender, and Range Rover Classic share in common?
So many similar axle parts. Weld on diff cover. Fill plug, hub flange gaskets
Sent from my EVO using Tapatalk 2
Antichrist
Time to step it up.
16" steel wheels (with the exception of the two part wheels) would fit any year/model, though technically they aren't shared since the actual PN's changed because of off-set & width changes. I can't be bothered to look up the part numbers.
Series joints are bigger than coiler joints.
Depends on the year. Early Series used 1300 series u-joints.
But I can't remember which the Series 1 used. If the S1 used the 1300 in the propshafts then that would fit everything except TD5 Defenders (though it might fit the rear propshaft on them as well).
gp01
