Dave Bennett
Adventurist
And everyone needs 33s. Except the guys with 33s, they need 35s...
LOL
I say go with the 33s...people get 32s all the time, and like me can't wait til their tires wear out and they can go up a size. 32s with armor and a family full with stock gears in my 4Runner has no issues on 6% mountain grades, i've towed very small loads and like box rocket had no issues maintaining 60 or so on the mountains. I will say that the truck pretty much hates it, but gears aren't going to change that. It simply needs more power. Gears will put me in a different range of power, where it will still be sluggish. I'd rather SC the pig!
my other rig is on 35s and 4.88s. Its perfect IMO. 4.88s would be too much for daily use on 33s i think. Really screams on the highway.
I say if you have 4.10 or 4.30 and don't plan going higher than a 33 I wouldn't waste time regearing.
Thanks for all of the input, guys. I just installed the lift and shocks, today. I don't think it sits as high as I expected, because my springs, front and back, have over 300,000 miles on them. Which, now I need to order shorter rear shocks because I bought 5125 9" which is suppose to be good for 2+" lift in the rear, but they are too long. After doing it, it looks like that 33s won't fit, anyway. But, I think 32s will fit. The 31s look fine, so I think I may stick with those, until I get the springs replaced all around.
I wouldn't use shorter shocks. the 9" shocks are what you want. As it sits the 9" shocks will probably be too short on extension. If you fully flex out the rear springs the side at full droop will probably be limited by shock. I am using the 9" OME shocks and had the same issue until I relocated my shock mounts. Now I can get the full range of travel without the shocks limiting compression or extension. If you are worried about bottoming out the shocks, I would add a taller bumpstop before running a shorter shock. Use the bumpstop to keep from bottoming out the shock.
32's will work great with the lift you have. I had 32x11.50s on my truck in the beginning and it was a good set up.
Suspension lifts do NOT allow fitment of larger tires. Unless... you change the factory bump stops or limit up travel. This is the most common misconception people have. You can fit the same size tires lifted or not. Suspension lift will make it "look" like the larger tires fit "better" and will help limit rubbing on road but that's about it.
Here's a picture of a stock Tacoma with 33x10.5 R15 on factory wheels and no lift.
[/URL]![]()
Yeah but that dude can't turn the wheels without digging into the firewall.
