California fuel storage containers...
doug720
Here are the various rules and regulations for portable fuel containers.
General:
Automatic Closure Spout
An automatic closure spout must automatically return to a closed position when not engaged for pouring. In addition, cans manufactured after the January 1, 2009 compliance date do not have secondary vent holes. These changes lessen chances for spillage.
Child Resistant Cap
In 2008, President Bush signed the Children's Gasoline Burn Prevention Act, requiring that portable gasoline containers manufactured for sale in the U.S. on or after January 17, 2009 adhere to certain child safety requirements. With that law in effect, gasoline joined charcoal lighter fluid, torch fuel and turpentine on the list of flammable substances whose containers are mandated to have child-resistant closures.
OSHA Approved
According to OSHA, only approved safety cans or Department of Transportation (DOT)-approved containers shall be used for the handling and use of gasoline in quantities of 5 gallons or less. OSHA defines a "safety can" as an approved container holding 5 gallons of gas or less with a spring-closing lid and spout cover, a means to relieve internal pressure and a flash-arresting screen. The spring-closing lid and spout cover is designed to keep liquid and vapor from escaping at ordinary temperatures and to lift slightly when exposed to excessive outside heat. OSHA defines "approved" as a gas can that has been listed or approved by a nationally recognized testing lab such as Factory Mutual Engineering Corp (FM), Underwriters Laboratories, Inc. (UL), or federal agencies such as the Bureau of Mines or U.S. Coast Guard. The most common safety can is the short and round red metal can with yellow labeling. Some are now available in high-density polyethylene plastic.
DOT Approved
DOT-approved containers are used more often by the general public. DOT-approved gas cans, or "jerry cans," have a screw-on cap instead of a spring-closing lid, spout cover or flash-arresting screen. They do not meet the "safety can" definition, but OSHA has decided that they pose very little hazard and meet the basic intent of the standard. DOT-approved gas cans will be labeled certified to meet American National Standards Institute and American Society for Testing and Materials standard ANSI/ASTM F852-86. OSHA recently started allowing plastic jerry cans, but most are metal.
Minimal Vapor Release
Standards set by the Environmental Protection Agency require gasoline containers to limit the release of volatile organic compounds into the atmosphere. According to the Portable Fuel Container Manufacturers Association, a gas can must be a permeation-resistant container that limits hydrocarbon leakage to 0.3 grams per gallon per day. Using a fuel can that limits gasoline vapor emissions contributes less to ground-level ozone (smog).
Label the Can
The Federal Hazardous Substance Act requires certain containers to alert consumers of the possible dangers that the contained product may pose. Accordingly, fuel cans must display proper warning labels to alert consumers of the potential hazards.
Older and Exempt Cans
Although standards are set for the manufacture of new containers, no laws exist preventing the use of old cans. Because of this, retailers who have remaining inventory of non-compliant, older cans may still sell them until they are gone. As of 2010, nothing requires replacement of old cans that may not comply with new industry standards. OSHA-approved metal safety containers, primarily utilized in commercial situations and not classified as portable fuel containers intended for residential use, also escape the new regulations.The regulations also have no bearing on cans for sale outside of the U.S.
Additional Safety Tips
Although not mandated, it's a good idea to adhere to established safety guidelines when dealing with the transportation or storage of a flammable liquid such as gasoline. According to the Environmental Protection Agency, you may want to make use of improved gas cans to reduce your exposure to vapors. Exercise care when dispensing gasoline and avoid spills by filling all equipment and vehicles on a hard surface and in a well-ventilated area, away from children and animals. Store gasoline in a cool, dry location. Because of the risk of heat or impact explosion, do not store gasoline in the trunk of a vehicle or in a vehicle itself
ASTM - Fuel storage container color rules:
ASTM specs for portable fuel containers determine color for fuel cans, not USDOT regs - that's why the US Mil can have any color they want for fuel containers. There may be individual state DOT requirements as well, but that's a patchwork.
I'll see if I can dig up the ASTM spec number(s) at work tomorrow. However, unlike USDOT regs, ASTM specs are proprietary; so unless you have access to an industrial and/or gov't organization library (like I do at Boring), then you won't be able to get a copy without paying for it (or someone gives you a bootleg copy :) ).
ASTM is also the reason why civilian jerry cans are shaped differently than MIL cans (i.e. wider and shorter) and won't fit mil jerry can holders.
(Copied from a EXPO post)
zelatore
Fixed it for ya:
An automatic closure spout must automatically return to a closed position when not engaged for pouring. In addition, cans manufactured after the January 1, 2009 compliance date do not have secondary vent holes. IN THEORY,These changes lessen chances for spillage. IN PRACTICE, THESE CHANGES GARUANTEE A 100% CHANCE OF SPILLAGE.
matthewp
Combat Truck Monkey
...not USDOT regs - that's why the US Mil can have any color they want for fuel containers.
Great info Doug! Thanks. One correction, the DoD is exempt from federal regulation (and therefore state regulations) in many different ways for military operational purposes. The DOT/misc. regs have nothing to do with the reason the fuel cans are different colors.
luckyjoe
What does this mean? Is a NATO can not a military container? Old to new mine are all the same...
Tom P.
sgregg108
Has anyone here actually been pulled over and cited for having non-red Scepter military fuel cans on their rig? I've got two and was planning on mounting them on the back of my Jeep in the near future.
luckyjoe
thanks for the find.... i think ill just get me some of these and avoid the headache
Please report back after you have had them on the trail. The appeal of the NATO fuel can has always been the reliability of the clamping-lid/leak-proof design. I just don't see that with a CARB-compliant plastic cap.
Tom P.
ismael D
i am posting a review of midwest can company fuel can
images.ashx
Martinjmpr
Wiffleball Batter
Interesting that we have a lot of anecdotal/second hand reports of people being ticketed for not having an approved gas container but no actual first hand experience. If someone has a ticket, please let us know what portion of the law is being cited. You can't write an individual a ticket for violating a law that individual is not required to obey.
In any case, I will be traveling to CA next month and plan on taking my 2 3 gallon RotoPax cans with their obnoxious CARB-compliant spouts.
I will also be bringing a completely non-CARB compliant spout off of my Bitz can, which, interestlingly enough, fits perfectly on my RotoPax cans.
However, I can assure you that the non-Carb spout is only being brought in to the state of CA for....."novelty purposes." :D
Jr_Explorer
That list just solidifies MY understanding of the law. That list states, "The following table provides a listing of those containers certified for sale."
You can USE any fuel can you own. You just can't legally sell anything that isn't on that list.
Houie
