Buying 2002 V10 Quigley need help/advice the clock is ticking need to make a choice
Jb1rd
Found this one not to far away and will go look at it if the guy ever calls me back. Its a bit RedNeck but nothing a little time with the heat gun wont fix.
Can someone tell me (Chris@UJOR) how there are 37's on a Quigley Conversion, should this scare me? I am going to look at the Van Friday and would like to know what to look for/ point out so I can get the best deal possible or run away!!
http://treasure.craigslist.org/cto/4276648914.html
86scotty
Cynic
Apparently the owner spent a lot of time hunting and not much time in school. I'm always amazed that people don't just let spell check do it's job.
Looks like a nice van, but I can't see the dash. Where is it? Oh, there it is. Couldn't see the forest for the trees. :Wow1:
Jb1rd
I am hoping this works to my advantage, but it could also be a disaster, kind of like "hey'all wach'is"
ujoint
Supporting Sponsor
ALWAYS be careful with a modified Quigley. I've had a few come thru here and they're always a basket case.
Not saying this one is but proceed with caution.
Jb1rd
What are the main things I should be looking for at? Drive shaft, ujoints, wheel bearings, shocks/leaf springs? Steering?
ujoint
Supporting Sponsor
Everything. Quality of workmanship, welds, angles of control arms, steering, etc. Drive it.
bknudtsen
I would ask the seller to send detailed photos of the front and rear suspension mods. If you get them, post them here. Things to look for are stacked blocks, coil spacers up front, excessive front pinion angle, steep control arm angles, relocation brackets for frame side control arm mounts, track bar drop bracket, track bar to drag link angle, type of steering linkage, giant dual steering stabilizers(compensating for death wobble?) Pics would help a ton.
Jb1rd
Will take and post pics when I get there thank you all for the help/suggestions
Jb1rd
Went to look at the Camo Van, gooooooood lord, the picture does not do it justice that thing is HUUUUUUUGE! 8" suspension lift body lift and 37" Toyos on 20" rockstar's. Actually looked decent but needed more more than it was worth as far as brakes misc engine and not to mention no power, she was a D-O-G!!!!!!
Cole
Sounds like the axle gears were never corrected for the tire size.
Houie
