Dual swing out
cdrewferd
Very nice. Can you post more detailed shots on the hinges? I'm thinking about a dual swing out for my 4Runner and am researching hinges right now.
Benc
I just used 2 3/4in heim joints on each side. It worked well for my set up because I could tie into the light guards. I have used just about every type of hinge on different swing outs over the years and IMO the 4x4 labs is the best. If you have a good base. It is a lot bigger than most spindle type hinges plus it has a built in stop. They are about $100 each but well worth it. I wouldn't worry about not having dual shear as long as the bumper is built right.
Benc
Benc
Wow, that is some really fantastic fab work...great job! I can't imagine how much time it must've taken to cut and dimple all those holes in the rack and bumper.
Thanks, yes it takes a lot of time and patience. I had I local shop cut the ones for the rack and then I dimpled them. The rest I cut with a hole saw in my drill press. The dimples do allow me to use thiner metal( 14&16 ga) where without them I would have needed at least 1/8 in so it saves a tone of weight. Plus they look cool
mizeide
Michael - Owner Wanderlust Overland
No noise, but saves a ton of weight
Yeah, I've understood the major benefits of dimple dies and being able to use the lighter gauge steel, I just always wondered about the noise in applications such as yours. Also, they look like they make for great tie down points!
Benc
I don't notice any more noise than normal and yes they do make great tie down points
TACO721
great looking truck and bumper/swing out!! like how you made the roof rack and bed side protection. Looks good all tied into gather.
vanhornsky
Looks great! What is the top lip measurement for your roof rack?Getting ready to build one myself.
Benc
Do you mean from the lower tube to the upper? That is about 2 in I believe.
iStan814
