Baja Rack UT
kojackJKU
Autism Family Travellers!
RSB, Does the bajarack indeed flip like the gobi for soft top useage? Is it designed into it? I know the gobi is available with a quick release for flip, is the bajarack the same? To the other poster, Bajarack has improved their materials that will stop the "sag" in the rack you describe. There was an article about it in O.J. last year. I love the fact that this rack is very low profile. And a almost 1/2 the price of a gobi, Im down for this one for sure.
rainstatebear
There are no instructions that say this but the design of the rear mounting brackets seem the same as the Gobi set up. I'm sure it could be done the same way. Would have to call Baja to see what they say.
Sent from the hand of the RSB himself!!!
kojackJKU
im going to call them when I get back from vacation and get the scoop for the flip. I like the low profile of this rack. its awesome.
rainstatebear
After looking at a bunch of Gobi photos I can't see why this wouldn't flip up just the same. If I wasn't living in a ducks paradise up here in the PNW I might go out and try if it ever stops raining. At least I will be able to report a rust report in a few years....
rainstatebear
Tech Specs from the site
Frame: 1” (25.4mm) ¾” (19.05mm) and 1/2’”(12.7mm). Front and Rear support beams 1.25” (31.75mm) Steel tubing.
Top Wind Deflector: .062” (1.57mm) 5050-H32 Aluminum
Finish: Epoxy primer (rust barrier) with black powder coating
Rack weight: 85 Lb (38.63Kg)
Weight Capacity: 300Lb (136 kg) Dynamic / 600 Lb (272 Kg) Static
Measurements: 53”(1346.2mm) Wide x 93.5” (2374.9 mm) Long x 2” (50.8mm) tall
Mounting method: Front and Rear support beams (included).
kojackJKU
thanks rsb. You can ship it to me to have it powdercoated and protective coating baked on if it does!
bluehash
I have a Gobi stealth.. and this makes me sad( I paid 1450, including shipping, with ladder, quick disconnects and deflector). I spent a year thinking about going for the rack
Anyway... this is good for you guys. If RSB can let us know about the hinge on the rear legs, we'll know if these can be hinged for the soft top.
The weight capacity is the same as the gobi(300/600). The design is very similar. I'm not sure if they licensed this from Gobi. The height, front mounts, rear leg design looks the same, at least from the pictures.
In a way this is good news! Competition.
rainstatebear
I have a Gobi stealth.. and this makes me sad( I paid 1450 ). I spent a year thinking about going for the rack
Post a pic of your rear rack hinge point here and I'll do the same.
rainstatebear
zhukoveli
