4bt diesel CJ based pickup truck
gavan
Amazing! I've been wanting to do something almost exactly like this! Where in Houston are you? I'd love to come see that thing sometime!
Southwest 610 area, feel free to stop by any time. PM me and I can give you my address. You can stare at my neighbor's Scout and get some ideas for your D44 CJ swap too.
MOAK
I would not say the noise is deafening, but I would not call it unnoticeable. I have very little sound insulation yet, and you can hold a conversation at speed without too much yelling, and use normal voices at idle. I was actually very impressed, I have been in some loud trucks. I think the loudest thing in most big diesels I have driven was the enormous engine driven fan - this thing has a pair of electrics that you can not hear over normal motor noise.
After a month or 2 of chasing around dumb conversion problems, like I am going to build upper radiator support v3.0 soon because I am not happy with the upper mount yet, I would drive it anywhere. I tried to design it around easily found parts, and I tried to make it easy to work on. I think I did a pretty good job with both of those goals! What it boils down to is a one ton truck thinly disguised as a Jeep. I would drive it anywhere. The Dodge Durango seats are even pretty comfy!
OK cool, that is the most concise / honest answer I've received from anyone that has down the 4bt swap. Hell's bells, we nearly have to yell now to be heard over the wind noise of the ragtop, so, we swap to hardtop, and insulate the bejeezus out of the firewall, I'm almost sold. Boiling it down to the 4 bt or the chevy LS1,, more info the better... thanks, be good, be safe, and good luck !!
gavan
LS1 and 4BT are some pretty solid choices.
LS1 will get worse mileage, but be a smaller, easier to install package (except the exhaust). It will be quieter and have more horsepower. It is a pretty common motor, and should be easy to find parts for.
4bt is arguably more reliable because there is very little to go wrong, and it will run without things like batteries. It is big and heavy, and a little bit of a mess to put in a vehicle. It should be just as easy to find parts for if you are just a little creative, they mostly come off of a 6BT anyways.
One thing I would really look at in alaska, depending on how deep you go in, is fuel availability. Lots of important stuff is powered by diesel up there, trucks, gen sets, heavy equipment, blah blah blah. I am sure there is a lot of gas powered stuff too, but if I needed a fuel in alaska, I would think I could find diesel easier. If you look at all the dumb "alaska gold" shows, everyone is driving a diesel pickup with a diesel transfer tank on the back, and running diesel equipment. If worse came to worse, I bet you could buy some overly expensive diesel from a logger or miner's transfer tank - if you ran out of gas, i do not know how easy it would be to get more. But I am completely speculating there. I could be way wrong. I have not bought gasoline for something besides a mower in 2 years, i might be a bit biased.
Dan Grec
If you stick to any kind of maintained road, you have very frequent gas stations (with gasoline and diesel.)
The Dalton Highway is the "most desolate road in North America" and it's only 240 miles from gas station to gas station.
gavan
Maintained road? Thats for suckers! :)
gavan
I have put at least 10,000 miles on this thing doing just about everything.
Pulling my other Jeep
Yard work (with my other Diesel...:))
Parts delivery
Even done a little wheeling, it does decent in the snow.
Getting 20ish MPG with relatively few problems.
SSF556
SE Expedition Society
Parts delivery
What is the top speed?
gavan
I usually go 70-75 on the highway, I have cruised 80 no problem. Never pushed it harder because I just have not had the need or desire. According to the math it can do 97 MPH but realistically it would be spinning pretty hard at 90 and falling off the fueling curve.
The real question is how much faster do you want to push hobbled together junk? :)
Joseph McCormack
