Quadrotrac
We've been together in Canada a few years ago. Really enjoyed that, hoping to do that again and eventually move over to Canada in a few years. http://www.expeditionportal.com/forum/threads/63891-Tour-de-Canada
I'm cutting the toolsteel on my power hacksaw, but it really eats up the saw blades. Took me a brand new one just to cut the four blanks.
I'm turning it with carbide inserts, but hispeed also works with a slow cutting speed and lots of coolant, especially while drilling.
Fabricated some gussets today:
Made a sparetire mount:
And started with the driveshaft: Bought one from a Jeep because i was told it would have enought angle:
Well, that`s by far not enought:
Didn`t want to scrap it again, so i thought of something:
Had a new boot for it. Unfortunately the cv joint fell apart when i was trying to install it. Took me the better part of the afternoon to get it back together:
Then i started cutting some (high strenght) steel:
And turned the connector:
Spent the better part of the day finishing that jeep driveshaft thing:
At this point i realized that it`s not going to work. Piece of **** Jeep driveshaft cost me 2 days of work, i was about to lit everything.
Then i decided to do it like i originally wanted and hope it`ll hold up. So i used a cv-joint from a fwd car:
That`s the carrier bearing on the joint nut:
Test fit of the rear part :
And made the front part:
Finished:
Let`s hope it`ll hold up...
Started welding it today. To get some airflow going i took a blower motor and hooked it up to a battery charger:
Started with the joint:
Still regaining control on my right hand, so no welding porn this time:
Made some gussets:
And welded them in:
Had some help to remove the cage. My mounts worked out like crap, need to change that:
Removed the body frame:
Pulled the engine:
Everything apart:
Started welding:
We have a saying in german (hopefully translated right): The day has 24hours and there`s the night too. :ylsmoke:
Made a diff cover first:
And welded a few hours:
Nice to have a welder with 100% duty cycle at 200amps...
Going to build a tranny cover tomorrow and probably give it a shot of paint...
chilliwak
Steinez I am glad to see you still at it.
I remeber this pic of you doing bodywork on my old Chev...
nice work greatly appreciated....
Made a transfercase and brake drum protector today:
Got everything out of my way:
Made some gussets for the axles:
Finished welding the axles and put the gussets on:
Got everthing ready for paint:
After shooting some paint:
Got some nice led strobes to go on the rear car:
chilliwak
Wow:Wow1:some serious looking progress there Steinez. Cool to see you getting the rig painted. I can see a test drive coming soon....:)
VanIsle_Greg
You know when it goes to paint... stuff is getting serious.
Looking awesome, love your builds. What part of Canada were you guys in, somewhere in BC if I recall?
Yeah, well, first plan was to complete the rear car so it is up and running and then start on the front one. But now i decided to just weld up all the stuff on the rear one, put it back together and set it in (outside :( )storage. I think i need to have the whole thing together before i can start running the wiring and hydro hoses and stuff. Same for the brakes and cables and stuff.
So it`ll probably be finished somewhere this week and i can start on the front car, i`m really excited about that. Need to finish welding and leak test the gas and hydraulic tank, weld up the hydraulic pump mount and i`m basically done with it for now.
We`ve been traveling from Vancouver up to Arrow Lake/Nakusp, then Sandon and Nelson, back to Chilliwack and Vancouver.
