Java's Mini Trailer
java
Thanks Guys, Now if I could just find some longer m10 full thread blots Id be happy.... They don't seem to exist locally.
Lucky j
Really dig your built.
Finally give the ideas to get going on my next trailer built. I just did not had the inspiration to start on the next trailer that would meet the smaller all around need.
Thank!
Keep on building!
java
Thank!
Keep on building!
Thanks! Glad it could be inspiring. I think the mini trailer is going to be perfect. Can't take too much crap, but fits the essentials when the truck is full
java
Not much in the way of progress. Need some sheet metal to go any further really, and its not in the budget :(
But my daughter and I were working on some little things the other night, and she was jumping in the trailer. And the tailgate fell off. Luckily she was just inside it, so she was fine, but both latches broke. Oops.
So in come anti-tail-gate fall-off tab.
Two screws and the tail gate can still come off, but now wont fall off :)
java
Java,
Where'd you get the barrel hinges? I've looked at McMaster-Carr and there are quite a few choices. I was a bit overwhelmed.
I actually got them at my local steel yard. Everett Steel. They have a bunch of different sizes. They are the basic ones, just a brass washer, no grease zerk or anything. That size was $3
java
Dimensions worked out well.
3 wide this way
Two wide this way.
Two deep!
Now I guess I need more Action Packers.....
matthewp
Combat Truck Monkey
I just stumbled on this build, I am very impressed. It's an awesome trailer! It's similar to my last trailer. You should get a lot off happy use out of it!
java
Thanks Matthew! I'm pretty happy with it! Need to get it finished for summer.
java
We have lid!!!! The steel yard just happened to have a piece of .080 aluminum that was the right size in the remnants pile.
Handle.
now I need a gas strut.
java
Lid done!
Closed
Powered by NWOL
Opens wide. Mule got their sticker in there.
Need to go get it inspected and get a title issued now.
java
Awesome job! What size gas struts did you use and how heavy was the lid?
Thanks! Lid is probably ~40 lbs. I didnt actually weigh it, but id guess the steel was 25 and the aluminum was 15. The strut is a 80# force 20" from seadog.
oskarf150
