Savana/ Express Van Builds
agelessGIANT
Question for owners with lifts installed... Do you think you can fit 255/85r16s? I know they are 33" but they are narrow so maybe there would be less if any rubbing. I have read the 285/65r16s rub. Any input would be appreciated.
Hobbs67
I just installed the Rough Country lift in my 2009 Savana AWD van. I used everything in the kit but the rear shocks. I ended up using NAPA gas shocks off a 2500 van. The part number is NS 76763, and bolted right in. They are a couple of inches longer than the 1500 rear shocks. I have 285/70R17 Coopers on factory GMC alloy wheels and they fit great. I trimmed the rear edge of the front fender opening on the wheel well side, but I probably didn't need to. The cut isn't visible unless you look in the wheel well. They rub a little at full lock on the frame side. I think 295's would fit. The biggest thing is wheel offset.
Mr. Nacho
Hello Hobbs67, I'd like to see some Pics of your van? I'm starting a new build next month with a 2010 GMC AWD Savana and would like to go with a larger tire than the 265/75R-16 with the 2.5" Maxx torsion Key lift I currently have. I agree offset is the deciding factor and I have long contemplated trimming that front fender piece you speak of. My van is also coming with a slider door so aftermarket wheel offset will have to be spot on:) I'd like to use Cooper A/T3's with Fuel D524 Dunes or Fuel Boost D534, the boost offer more offset options so are most likely candidate.. Mr.Nacho
fog cutter
got it in july. got three layers of 3 oz. primaloft in the walls and two 4 oz. in the ceiling, formica wall & ceiling panels fabricated and fitted in august. working on the cabinets now. send $$$ !
Michael Crouch
Curious for those with AWD - what kind of roads are you capable of getting on? I'm lurking around for a van and the Express is looking good, but I end up in Mexico and other spots that I'd be worried about without 4L.
jdharrin
I've been hitting up forest roads all over CO and mine does pretty well with a small lift but you need to adjust your technique (momentum is your friend). Doesn't hurt to have a high risk tolerance for damage either. Where the lack of low really hurts you is when you need to use reverse so planning is key.
Houie
