Hi Frank - glad you're still keeping up with it! And thanks for the link to handybob - been there! Love his outspoken opinions backed up with real world experience.
Just so folks have a sense of the details - here's some of the electrical doings - bearing in mind I am a novice in this department, but happy to experiment (but very very carefully with anything involving amps!).
Here's the solar controller and RCD for mains hookups. The 350W inverter is situated above it - that's its base you can see at frame top. Its still not wired in yet. All this is just behind the drivers seat, separated from the main area by a wood partition so its not easily interfered with, or can easily have a cup of tea dropped onto it.
The solar panel is at roof rear (the 'top' of the lifted part) and instead of running the wires down the outside I went down the inside, hard up against the inside of the alloy. The fabric sides will be screwed up into the pine panel at top leaving a good gap between the fabric and the solar wires.
All the wiring coming down the lifting section (solar and light wiring) has to flex round the end down into the lower area and I've run the smaller stuff through clear plastic tube (garden variety from the hardware store - I had a load of this left - I used it to run my brake pipes through to protect the piping). I reckon this will give the wiring a good bit of protection. The heavier solar cable is in flexy black plastic conduit. And all this well fastened down with cable ties or wire clips.
The lighting wiring will be hidden behind a piece of thin ply which I can fasten into the timber end to keep that looking neat and tidy.
The fusebox for all the stuff running off the aux battery is currently situated just beside the battery box, in the area between the front seats. However I've pulled out the third (middle) seat and replaced it with a home-made cubby box that conceals and protects the fusebox, and hinges forwards to reveal it.
I may relocate this at some point but at the moment its fine.
PS - The loose wires visible are yet to be properly trimmed and run through the black conduit, then fixed to the bulkhead - work in progress.
