limp_noodle
Did you take them to a machine shop to have the center opened up?
What are the specs on the wheels?
Used a small grinder to tabs and made opening just a hair larger than needed to make sure lugs would center wheels. I think the best alternative for 16" wheels is tacoma aluminum they are available cheap and you only need to remove 1mm of material to make them fit and im sure that can be done with a course cylinder hone.I am trying that next.
