M101A2 jitter stop
Pccruiser
Sometimes when stopping, even when stopping slowly and carefully, my trailer gets into this mode where it bounces back and forth and the surge brakes keep locking up the trailer brakes.
It's really annoying and sounds horrible. Any idea on how to prevent this?
Mark Harley
TM 9-2330-202-14&P,
Part number is 1844-2
Cage code is 93072
A quick search of the cage code comes back to Toledo Stamping and Mfg.
A Google search yielded this info.
Toledo Actuators | Balcrank Products Inc. Customer Service 800-747-5300 Fax 800-763-0840
Still uses the same part number.
Pccruiser
TM 9-2330-202-14&P,
Cage code is 93072
Mark is that for the entire surge system? Not sure what you intend with that info. What part do you think is faulty? I can't lookup until later tonight.
Thanks!
Paul
Pccruiser
Yes he does. Thanks E! And thanks for the part numbers Mark! I already talked to them and will be ordering it on Monday.
Voltronjacko
Excellent. Exactly what I needed. Anyone have any experience or tips for switching this shock absorber out? Looks a little daunting.
Pccruiser
I spoke with Calvin Mendenhall with Mendenhall Industries (who manufactures the OEM shock) and he explained how to handle it. Apparently there are two ways depending on if the manufacturer used OEM or knock off shocks.
I'll do a write up about it when I do it in a couple weekends. Won't have time until then.
Voltronjacko
Do you come at it from the master cylinder side or the hitch side underneath? Can I move the master cylinder without having to disconnect the brake lines? Trying to not have to bleed the brakes again if I can help it.
zhukoveli
