Show us your Toyota 4runner, tacoma or truck.
ReconRunner
I took I believe one inch and one and a half inch pvc pipe that fit perfectly inside each other at home depot. Then I drilled a number of holes on the inside poles and one hole on the outside pole for adjustability. I can slide a pin in it for support. I then capped off the top of the inside pole which is what rests against the awning. I drilled a hole in the caps and ran a long stainless steel bolt through it with two nuts at the top to cinch it down so it wouldn't unscrew. The tarp is just a cheap brown tarp from home depot. I can retract the poles and roll them into the tarp when I stow it on top of the roof rack.
ReconRunner
Here is a few more pictures of the tire and gas can carrier I built a couple of weeks ago.
ReconRunner
Sure. Is this what you were looking for or did you mean during the build process? If you closely enough you can see the hitch is hidden and tucked a lot higher for a better departure angle. The third gens with hitches have a big problem dragging. Since I did that I havent dragged once.
Are Squared
A couple more
2010 Tacoma Double Cab
OME 2.5" HD Lift
ProComp Wheels
Aluminess front and rear bumpers w/t swingouts for tire and fuel
Warn 9000
Baja Rack on Cab
Yakima Whispbar HD on topper
Cooper Tires Discoverer A/T 3's
Flat black hood wrap
More in the works.
dlichterman
OME 2.5" HD Lift
ProComp Wheels
Aluminess front and rear bumpers w/t singouts for tire and fuel
Warn 9000
Baja Rack on Cab
More in the works.
Digging that fuel can rack you have there!
GhostRing
Coupla nice lookin' rear ends there :drool:
Thanks for the extra pics, I can definitely see the concept better now. Great idea!
dlichterman
Finally got all the parts and had my 2001 Tundra lifted
getoutside
Here is a couple (double posted the same one and can't seem to figure out how to fix it, sorry about that) of my 09 from today at Monti Zebio just north of Asiago, Italy in the Dolomites on the southern edge of the Alps. Just a few upgrades now (bttm of page) but plenty of plans for the future.
seth.c96
