Gen 2.5 Mitsubishi Montero 2000 - Over-landing Family Truck - long term enhancement
raysobi
Sigh....
I changed a transmission fluid last night and my wife yelling at me that food is getting cold. I rushed it and put screw back without an O ring.....woke up this morning and found small drips all over argggg!
Its definitely her fault LOLOL!
Btw, does Montero 2.5 have transmission oil filter? Because I know some car don't and it is pretty common.
raysobi
Took me 5 hours to change the spark plugs because I had to remove the engine....
Ok I am being over the top.....but really Mitsubishi? Phew!!!!!
nwoods
You are braver than I. I need to do it, but I struggle with mechanical things. I've only recently learned how to unscrew the gas cap :)
Getting down to the spark plugs in this thing looks like quite a chore.
earljuic3
I don't own a 2.5 I have a gen 3 but I did plugs / wires / valve cover gaskets / and coil packs a few months back...HOLY HELL so ridiculous how difficult they make it..especially on a truck that if taken care of will last a very long time
MontyMcV
How many miles? I cannot find in the thread posts. If around the 120k service interval, there are other things I would do with the timing belt and spark plugs. If you are below that, be sure to plan on doing more work with the next t-belt/tune-up.
raysobi
Replace a reveal for windshield.
Pop it up, but do it very slowly because you do not want to damage the inner clips.
The green inner clippers are still in good condition (and I also didn't buy extras).
Old vs New
Upper reveal
Left side reveal
All out
Pop in the new!
Easy as pie, and the longest part was to make sure I didnt damage the inner clips!!
This weekend I will spray paint the whiper arms since they are hideous.
nckwltn
Replace the reveal for the windshield.
Pop in the new!
awesome! I actually need to replace the seal along the bottom, it seems to have some kind of adhesive on it, is that a 'glass company' job?
raysobi
Old vs New
Upper reveal
Left side reveal
All out
Pop in the new!
I did not replace the bottom part because it is still in a good shape and I am not in a hurry to replace it because it's not cheap.
However, I am expecting the bottom reveal to be like the rest of all other sides.
I also did not use any sealing adhesive because I don't think I need to after a research and watching YouTube.
Outer Weatherstrip Replacement: http://youtu.be/YUEUad4s9DY
Similar to windshield reveals replacement, the only thing I didn't use was a rubber mallet....since I used my fist instead. Speaking of my fist as a mallet...I need to get an ice pack.
raysobi
Front Torsion Bar adjustment
So I had been reading and searching the internet but it seems like I am hitting the dead end.
I am a very visual person and I need help!
These are the pictures that I took, which one is the torsion bar bolt? Or I'm not even close?
:eek:
nckwltn
:eek:
This picture is the torsion bar. It runs horizontal. I've never tightened the bars though.. I assume that you lift the front end to take all weight off the bars, then tighten them with equal turns for both driver and passenger sides.
**Edit - this is bad advice, you want the car on the ground (see jlocster post below)
raysobi
I think I might be mislead when I read several forums.
For this particular model Montero2.5, do you adjust it by turning the bar itself? Or turning the bolts? Or both?
zhukoveli
