Post your Mitsubishi Pajero Pics
Djbenny
I swapped over my Gen 2 Wheels tonight. They are wrapped with 33" BFGs!
jhill15
Good looking Rig! Do you have a lift for those 33's? Im in the market for some tires and want to go bigger but wasnt sure how big I could go sitting on the stock suspension.
SoCalMonty
No. The .3rd gen has a way smaller center bore.
Without hubcentric rings, you'll most likely get a nasty speed wobble at freeway speeds any time you put a wheel with a larger center bore on a smaller hub diameter - it needs to fit flush around the hub or it will shake. The lugs aren't enough to center it accurately and hold it tight.
fury311
Yep, Nathan is correct!
1" BL, Ironman torsions and coils, KYB GAJ, deleted swaybars, low pro bumpstops up and down, 1" wheel spacers all around, and 33x12.5s.
Thank you! :)
awesome. im gonna go for ome coils. and hopefully thatll be enough to get rid of the swaybars. hows the ride without them? are the ironman coils stiffer than stock?
jeep-N-montero
Really? I have ran lug centric wheels on both Jeeps, the Miata, and the off road trailer for many miles and years with zero issues.
Djbenny
Thank you! I have no lift, stock suspension. They fit fine, I just had to polish down the calipers on the front to fit the 15" wheels. I didn't put hub centric rings and at highway speeds no wobble or any vibration. The Gen 3 rims will not fit on the front of a Gen 2. Because of the difference in hub size. I don't think the spare tire carrier will allow a 33" to sit back there though. JFYI.
Salvation Mountain! Looking good! Where are the other shots taken? Joshua Tree area?
first 2 pics is at hungry valley in the rain, the next 3 in joshua tree, then in front of the integratron sound bath in landers,ca then salvation mountain and the last pic is at a music festival called lightning in a bottle.
