2UZ-FE Cylinder Heads w/ Cams and Sprockets
dyogim
I have a set of cylinder heads from a toyota 2UZ-FE motor. Was off of my 2000 Tundra 4x4. It had about 160K miles. Motor was replaced due to blue smoke coming from the tailpipe. Had plans on rebuilding the heads onto a block I have with only 5K miles (also for sale). However, funds and time is scarce. Cams and sprockets are included.
Other side is in the same condition. Debris is from when I had removed the head from the block and moved it around. Weight for each head is about 50lbs. Dimensions for packaging each is approx. 24"L x 12"W x 12"H. Shipped from Concord, CA 94521.
Asking price $100 each or $175 for both. Buyer pays shipping. (pending sale)
RBKI3Sc1byQ6ujOvbvpTSj6QRT6FwxCpmN522ioP8yI=w868-h491-no
dyogim
Along with the items currently being sold, I'm adding to the list.
Heads: $175 for both or $100 each side. (pending sale)
Upper/lower oil pan and strainer: $75 (sold)
Short block: $100 (with crank, flywheel, rods/piston heads). Otherwise, individual pieces are detailed below.
Crank: $50
Rods/piston heads: $15 each pair
Valve covers (both): $30
Flywheel: $15
Block (bare): $50
Alternator: Sold
AC Compressor: Sold
dyogim
DanoWall
