Collection of Trailer Builds
dales133
Started mine a few days ago, here's a teaser
MonsterJ
Here's a couple teasers of what I built this past week. Once I have time to sit down and do a proper build thread, I'll update this with a link. I've had the GoPro running the whole time during the build doing a time lapse. It will be a fun video to see once I'm finished.
mep1811
Gentleman Adventurer
Thanks, it's for sale! I can't recall the exact brands. However I just bought a heavy duty off road swivel wheel and bolted it to the jack plate.
-Daniel Kent
I bought two tires at Harbor Freight. The problem is the tires constantly lose air ,even with slime in them. I've now seen no flat tires at Tractor Supply and Harbor Freight and will be on my list of things to do.IMG_20141030_082929_820.jpg
teotwaki
Excelsior!
Start by replacing the valve stem core then stick in a whole new tube if needed.
bunger
Solid types are way less hassle.
Operate almost as well but never go flat
I originally had solid tires on mine but they always dig into my lawn when I would hand maneuver the trailer into it's storage location. I went with a pneumatic tire and now it just floats over the lawn.
HAFICON
Sorta off topic, how many of you have trailer brakes on you Expo trailer. Mine will be a 6'x5' cargo area around 24" total height, frame will be 2" x 3" square tubing thinking maybe channel over tubing (dont know yet). Typical load will be some extra fuel, water, spare tire, maybe one day a RTT, and other small items. Would you suggest an axle with brakes?
Xrunner
Do you absolutely need them? Probably not.
I prefer them for extra control they afford and the mental security in knowing that they are there should I ever need them.
The cost of adding them to a from-scratch build is usually pretty low too... probably a few hundred dollars in parts if your tow vehicle already has a break controller.
abctrash
