Not much of an update.  My springs will be delivered on Monday, at least that's what the carrier said on Friday, but other than that nothing much accomplished.  Been down hard for a solid week with some kind of intestinal issue.  Didn't get out of bed or eat for 3 solid days, which didn't matter cause I couldn't keep anything in anyway.  Upside is I lost 8 lbs.
But, one little thing.  I've been looking for a way of storing various things that were quickly accessible, yet out of the way when I didn't want/need them.  One of those things happened to be a couple of 1st aid kits.  My solution...
[/URL][/IMG]
That panel is about 11"x16".  One side is covered in Pals webbing and the other side is covered in velcro and it has a plastic stiffener inside to keep it rigid.  I bought 3 of these (so far) and will mount a couple to an access door just inside the main door into the box.  This one has a small and medium sized first aid pouch attached.
[/URL][/IMG]
The little pouch is just a smaller copy of the bigger one.  One word of advice to anyone using Pals webbing, do yourself a favor and ditch the malice clips.  I've come to the conclusion they're called malice clips because during the process of trying to thread them through your pouch and the webbing you develop quite a bit of it towards whoever invented the blasted things.  Spring the extra money and buy the Molle Stix.  They are worlds easier to install and have the added benefit of turning your pouch into a quick release item.
[/URL][/IMG]
The Molle Stix are rigid which makes threading them easier, and you only have to thread one direction.  Once in place you snap the top part down and it keeps everything in place.  Tie those two cords together, then you just give a good yank and the clips release, pull out, and drop the pouch free.
Anyway, one panel will hold my 1st aid gear and maybe a decent sized fixed blade utility knife.  Another will hold some general "stuff"in a pouch.  Leatherman, pen, paper, etc.  There will be space on the outside for a flashlight, HT radio, etc.  One of the panels will probably be mounted with the velcro side out to hold pouches with velcro backing for REALLY quick release stuff, whatever that may be.
Once I get the stuff mounted up I'll get some installed pics.  Won't be all that exciting but it might give folks some ideas for non-traditional storage  on what would otherwise be empty wall space.
