Project: Family Overlander
Ranger Steve
Well going back 6-8 years ago I had a lifted zj on 4.5" with 33's. 44a rear and 30 from with Aussie. 4.56 gears, trimmed, snorkel with all vent lines extender to it ect. I had to get ride of it when life got in the way.
Fast forward to a few weeks ago I had the bug and it hit me like a ton of bricks. I just knew I had to get another grand Cherokee and get back into the woods. This time with my family. I went it looked at a bunch and then found a diamond in the rough. Low mile, 2000 grand Cherokee limited. All the bells and whistles minus adjustable pedals which was fine.
This jeep was gross. It looked like the guy lived in it. Old food bags of every fast food place. Food scraps in every crevice you could imagine. Trunk full of garbage to the point of when he opened it a landslide happened.
My wife was disgusted at the site but at the price I offered him to buy it the deal was too good not to buy the jeep.
First thing was I sent it off to a detailer. I wasn't going to touch the inside of it. I mean I was grossed out too. When I picked it up I was amazed. Six hours of two guys cleaning and it came out great. Just about every coffee and grease stain gone too.
About a week into ownership I realized the passenger side doesn't have heat and the jeep would make a weird noise while braking but only if I brake hard enough. The brake issue was the t-case shifter cable rubbing which was easily fixed.
I ordered the blenddorstor kit and worked outside in the pitch black to fix it. Well I had a flashlight. Start to finish took 1.5 hours including set up and clean up. Probable could have done it in an hour if I wasn't trying to position a flashlight the whole time.
Now with a clean jeep and heat my wife is happy again. However I'm not. Last week I ordered IRO 3" kit with adjustable track bar, all new isolators, moog super trail boss steering stabilizer and bilstein 5100's. I'm waiting for all those parts to come in.
Today I'm going to score JK rubicon take offs to use with the lift.
Ranger Steve
Nice jeep and nice find on the wheels. Have you gotten wheel adapters to make them work on your axles?
WJ Bolt pattern are the same 5 on 5 as a Jk. Same as WK too. Works out good for both parties as most rubicon JK's end up going bigger and it's always hard to sell off stock tires. However a small lift on a WJ and they fit great and don't break the bank with lift, tires, axles ect.
madZJ
You might have some rubbing issues with those JK takeoffs. Nothing a little trimming and maybe a 3/4" spacer lift can't fix. Not a bad looking dub to start with.
Ranger Steve
Yea I don't mind trimming. I've been checking out the 10mm which is 3/8" spacers. I've been seeing mix results about running with 32" at 3" lift. This jeep won't get taken rock crawling for a while so I think I'll be ok. I could always extend the bump stops too
jscusmcvet
Huh, had no idea the WJ bolt pattern was the same as JK. Good on ya. It is going to be a great family machine for sure.
Ranger Steve
Installed Fawkes Fabrication front shackle tabs. These things are pure beef. For rear recover I have the factory hitch and shackle receiver shackle. With recovery points front and rear i feel more comfortable going in the woods.
oskarf150
