Strange oil pressure gauge behaviour on Land Rover 110 200Tdi - need advice!
wuntenn
I have a bank of three gauges on my dash, oil temp and oil pressure and water temp.
Each gauge has a Pos+ and Neg- wire for the small illuminating light, and three other terminals for Pos+ and Neg- and S for signal. They are wired as follows:
They've worked fine for 6 years and two weeks ago the oil pressure gauge (and only that gauge) went off the scale suddenly - hard to the right side, which is over 100PSI. I stopped and checked everything but the engine seemed fine, but blipping the throttle had it pinging the needle over to the right like a mad thing.
The circuit has the Oil pressure gauge in the middle as shown above, with the water temp and oil temp on either side, all sharing a common earth and power supply. The other two gauges when wired like this both work perfectly, rising/falling as appropriate to the state of the engine, but the middle oil pressure gauge goes off the scale.
Things I have done so far:
I changed the sender (transducer) unit on the oil line for a new one - needle still goes off the scale.
I ran a new separate wire from the sender to the gauge (so not using the old signal wire at all) - and needle still deflects off the scale.
I then ran a separate power and earth wire direct from the battery to the gauge and the needle still went off the scale.
I assumed the actual gauge on the dash must be defective so fitted a new one. Needle still went off the scale exactly the same as the old one!
I was surprised to note that I can also get the needle to go off the scale WITHOUT the sender wire attached - so only a power and earth connection, which seemed rather strange. I tried this in the house with the old gauge and new one too - attach a wire from Pos and Neg to a battery and the needle goes off the scale.
Now the odd thing - if I leave the earth wire disconnected it makes the gauge work 'normally' with no needle deflection - I tried it inside the house with a couple of wires and one of the gauges and a transducer with the Pos and Signal terminals connected onto a 9V radio battery. So obviously the sender resistance determines the needle activity.
However with the whole plot fitted on the van the gauge wont work, not with old wiring nor with new wiring, not in its original state with the earth connected, nor with the earth disconnected. It obviously DID work with all the wires connected previously as its been like this for 6 years.
I cannot understand why the existing wiring setup has suddenly made the gauge go awol, and if its some strange earth problem why its only affecting one of the three gauges. Today I disconnected the earths going to chassis and gearbox and scrubbed them up and coated with vaseline and retightened them. But no use, I've still got the problem.
SO to recap:
attaching all the wires gets needle off the scale, with the gauge (new one and old one) on the van or off the van.
attaching only Pos and Signal wires on the gauge OFF the van gets it working (it appears) as normal.
attaching only Pos and Signal wires with gauge and transducer in their correct locations on the vehicle gets nothing.
Now the only variable in all of this that I am aware of that has made its presence felt recently is that I have developed a diesel injection pump leak - oil line and transducer & wiring is directly below the diesel pump and some diesel is getting onto the sender end of the system. Could this be the culprit? (Diesel pump is being replaced shortly)
I am perplexed!
(PS have had some good advice on a UK forum but its not led me anywhere near a solution!)
rayra
Possibility something else entirely is bleeding voltage to your chassis / ground and the design of the oil gauge is more susceptible to the problem.
wuntenn
Thanks. It might be quite likely. The fact it was working ok for years then suddenly went awol suggests a specific problem like that. I need to do some more wire poking!
proper4wd
The ground connections in the dashboard are notoriously questionable on Defenders. In fact, the entire dash harness in general can be problematic.
Start checking resistance to ground first - even better if you can do a load test. check the earth connections where the dash harness terminates.
wuntenn
Yes thanks for the suggestion - I'm heading in that direction shortly! I was poking about in there a couple of times prior to the malfunction and although everything was fine immediately afterwards its possible I've loosened something that has subsequently parted company with a terminal and is giving me this glitch.
Good thing about all this is that it improves your electrical ability very rapidly!
jeffjeeptj
Try grounding the sensor case at the engine. Have you recently worked on the chassis or engine block grounds? Is there a wire between the body and the bonnet, chassis, or block that has a poor connection?
Since the other gauges work properly and you have replaced the sensor and the gauge, and you have tried new power and ground connections.
Just had a thought, check the signal wire between the sensor and the gauge. Continuity or grounded?
Hope this helps
jeffjeeptj
Try grounding the sensor case at the engine. Have you recently worked on the chassis or engine block grounds? Is there a ground wire between the body and the bonnet, chassis, or block that has a poor connection?
Hope this helps
wuntenn
Hi Jeff - thanks for chiming in. No, no work on chassis or block grounds. But I removed both a few days ago and cleaned up well, and refixed. Still no solution.
I'll try grounding the sensor at the engine and see what happens. I'm waiting until I get the leaking fuel pump (which is directly above it) replaced so it's not all covered in diesel.
I'll keep you in the loop!
zhukoveli
