Eurosonic's Montero 2.5Gen Build Thread
BOPOH
while the engine is out you can check and clean from locker assembly, that's what im going to work for now
BOPOH
well what ever that thing is
BOPOH
oh by the way my engine did sound like diesel too which appears to be bad bearings, cranshaft and cams were to loose. I hope everything works out good for you
eurosonic
I've removed that assembly completely when I installed the front pumpkin with gears from a Montero Sport. Less things to worry about breaking
BTW where do you get these schematic diagrams?
BOPOH
do you have it somewhere in this thread? i'd like to read more about this swap. that diagram i just googled, usually you can find something like that from autozone website too
eurosonic
Yes, I have the conversion documented earlier in the thread
eurosonic
IG - Instagram.
Ill be servicing all the adjusters while Im at it.
Ill take a look at the alternator. Im sure its filthy.
eurosonic
Taking out the valve train so I can replace valve stem seals and lap/clean the valves. Made this tool so I can compress the spring and remove the retainers.
eurosonic
Soaking parts in some nasty marinade of chemicals. Results are beyond fantastic. Will post more later
Block somewhat cleaned up
Well. Both of my exhaust manifolds are cracked.
Truck sits so tall with out all the weight.
darrylkd
