6x10 base camp/duck hunting/household goods mover
HAFICON
Ahahahha ya having the hangar to work in while on weekend duty is pretty nice. $60,000 tool boxes with aircraft grade tools at my disposal and a wash spot that I can wash my truck or trailer with 120* water.
Also have a 6ton overhead crane that I can use
Putting my roof rack on
DAMN Air Dale.. *L* I am stationed out of Woods Hole over on Cape Cod. Live on the Air Station here seeing these pictures make me jealous of your job of course (MK Here) and your work place. I been working on building my trailer from scratch in the freezing cold and snow. *L* But great looking set up man beautiful country also.
My work place all 87' of it.
uscg2008
Truck and trailer are both looking good. Is there a way to bypass the reverse gear and turn on the camera while driving so you could monitor the trailer if wanted?
ya there could be but i would have to add in a switch and power from a different spot. But it is possible I have scene a couple other Tacoma guys do it.
hahahah thanks brother. I def love being aviation!!! Having the hangar to work in is nice.
Sent ya a PM!!! From another AIR DALE!!!
Shipmate!
:bike_rider:
uscg2008
Got my Insulation put in yesterday, I used sheets of Reflectix that I got from home depot. I didn't need anything more than this since the coldest it gets where I will be using it the most is into the 20s. I already have a 15* sleeping bag plus the mr buddy propane heater. I run that a little bit before I got to bed and when I wake up as needed. I put it on the walls, ceiling and rear ramp under the plywood deck, and all of it was put up with 3m spray adhesive to hold it in place. Still kinda in between on whether or not I will put some under the floor of the trailer..... I guess I will have to wait and see what it is like when it is cold out.
toyotech
Looks good. I'm still working on insulating my aluminum topper on my tundra. I got styrofoam installed and I also picked up a roll of reflective sheets to help even more.
uscg2008
Even for being so thin it works pretty dang good. I know with one or two people putting off body heat and mr buddy it will be ice and toasty in there.
uscg2008
Well I can work on my junk but I have to bring my own tools. Ya one of our tool boxes is $60,000 without all the special tools that we add to it once we get it.
uscg2008
Well i finished up the trailer today, I fiinished all the wiring and got all the panels back on.
Back of the switch panel, looks kinda messing but everything is labeled
This where I ran the wire up from under the floor
This is where it comes out so I can mount it to the fuse panel
All the switches. The white one is for the dome light that runs off of the trucks battery while hooked up
Cut two holes in the trim and hooked up both outlets there
One is just a 12v socket and one is USB
And with power applied
The 6 blade blue seas fuse panel all hooked up
With all the panels back in place and floor a nice and vaccumed up
toyotech
Nice work. I want an enclosed trailer for my RzR so I can double it as a camper. Only use the rzr a few times a year. Other times. I rather not pull a trailer for my adventures. I do want to build up an enclosed trailer but I just won't get much use out of it. So far I have been having fun building my topper on my tundra.
uscg2008
Got my interior lighting in today. With two 6 foot sections, if I need more light all I need to do is attach more with the special no solder connectors that I got.
uscg2008
So I finally got around to mounting my lights. They come with double sided tape and I mounted them to the roof ribs. Now they are bight but not blinding which is perfect.
Lit up
This is one strip only, you can see that they put out a very good amount of light for only being 3 feet long
Lights off
And on, let there be light!!
From the side door
And some night shots of my exterior lights
Off
On
seth.c96
