My M416 Trailer Build:
72rallye440
Big thanks to Flashole for the help with the lid dimensions which helped a TON! Here's an update on the lid and I'm proud to say it is done!
72rallye440
I thought I would also pass on a little personal experience on the gas shocks that was a trial and error fiasco at best!
The lid is 1" square tubing and the "skin" is 14 gauge steel. I would guess the lid to weight about 175 pounds total. I started with 2- 175lb shocks and that was way, way to much and after putting 2, 100lb kids on it trying to close it I knew it wouldn't work.
I followed up with 2-75lb shocks and they worked but it took a little too much effort to get it open and when closing it slammed shut within about 18" of being closed.
Finally I moved to 2- 125lb shocks and all thought I think 100lb would work I'm sticking with the 125's. Opens perfectly with little effort but closing takes both hands and a firm pull to get it started. If I do decided to add a RTT I think it would be just fine.
Hope my rambling helps someone out there tackling the same project.
Kiddmen57
Supporting Sponsor
I just went through this designing my lid. I am waiting for the lid to be fabircated and then I need to mount my tent, but I think I've got the shock length and load rating such that I'm about 40lbs at both open and close to overcome the lid weight. There were some good links I found to explain the forces, you can look them up in this thread
http://www.expeditionportal.com/forum/threads/81419-Which-Struts-for-a-steel-M416-Lid
72rallye440
I'm looking for some input or advise. I'm running the original Pintle and lunette and do not want to change (I like it). I want to add a tongue box to my M416 (pictured).
I have an extra lunette ring that I want to cut down and extend about another 2 feet. Any advise, do's, don'ts before I do this?
Thanks in advance..
72rallye440
I spy a Charger :victory:
1972 Rallye Charger 440 4 speed, B5 blue, B5 blue interior, track pak (Dana 60), with left over 71 RamCharger hood. One of 129 4 speeds built in 72 and one of less that 17 with a originally equipped RamCharger hood option. I added a 6 pack for fun...
Thanks for noticing!
Greenjp3b
That is the the best resto/ modifi M416! I appreciate that you kept the stock wheels & NDTs. too often M416s are so over built you can't recognize what they were. Good work and enjoy.
67tank
Thanks in advance..
Really Outstanding Job. I like seeing other 416 owners keeping it close to stock as possible. As for the lunette - I kept mine stock. That's my preference. I like keeping the trailer tucked in close to my 83 Cj /13 Rubi and I like the way it tracks behind. The lunette is drop-forged (got it from Midwest Military) and if you cut and extend.....you will creating a weak point. I did bend my drop forged one on the rubicon trail one year but i probably shouldn't have taken my trailer on that trail.
However, my buddy extended his coupling (ditched the lunette) on his M716 trailer and he is very happy with its performance.
