= CONSTANT 12V powerDid a few things over the weekend to the Gen 3:
1. Moved my manual A/C controls to the lower storage bin location to make room for a double DIN stereo (Pioneer AVIC-5000NEX).
Nice job man!Did a few things over the weekend to the Gen 3:
2. Installed aforementioned double DIN stereo, running and hiding wires for the GPS antenna and hands free mic.
3. Added two USB ports to the storage bin. These USB ports are connected to the back of the Pioneer and allow for charging and Apple Carplay.
4. (nearly) FREE MOD. Swapped the accessory power relay for a jumper making the storage bin and rear cargo 12v accessory ports constant power! Now I can run my ARB Fridge with no worries
View attachment 273609 + View attachment 273610 = CONSTANT 12V power
5. Replaced blown subwoofer -- went with a Polk db840 8" unit. Talk about a pain getting all the plastic removed to get to it :ar15:
Nice job man!
Did your sub still work but sound blown or did it just stop working all together? I need to replace mine but im not sure if its just the sub or amp related cause it doesnt work at all.
Thanks man, I will have to wait until spring to tear into it. We are supposed to have 10 inches of snow by thirday evening.In my case it was obvious that it was blown. The separated cone just sat there rattling on certain tunes.
It is a lot of plastic to remove, but the amp is right there as well so you can try testing. If you were closer I'd give you my old radio so you could test to ensure it wasn't head unit related.
-vanroth
-vanroth
Gen 3:
