1999 Toyota Landcruiser UZJ100 - $11500 - Phoenix, AZ - Locked
OverlandTheWorld
OverlandTheWorld.com
*SOLD*
1999 Toyota Landcruiser UZJ100 - Located in Scottsdale, AZ. Please contact me for a test drive.
Rear OEM locker
Front ARB locker with Compressor
Custom front bumper & skid plate
Sliders
Rear bumper -- 4x4Labs dual swing out tire carrier with basket
230k miles -- Complete maintenance history at Camelback Toyota
Clear Title & CarFax
Factory Rear A/C
Warn Winch
Total Chaos UCA's
Radflo 2.5 remote res. Shocks
SONY Double DIN stereo XAV-60
Recent Maintenance History (not including Oil Changes):
172k -- Front Diff, ARB, CV boots replaced, Complete Front Carrier Assembly replaced
175k -- Steering Rack replaced, Alignment
179k -- Radiator hoses, coolant
192k -- Axle seals & reclamp CV boots
193k -- Rack & Pinion, boots
196k -- 2nd Timing Belt, Water pump, Pulleys, Tensioner, Fan Clutch, coolant flush
197k -- Tie rods replaced, Front brake job
200k -- Total Chaos UCA's & 2.5 Radflo remote reservoir shocks installed
207k -- Rear Lower Control arms
217k -- New alternator, battery hold down
218k -- New seat belts, New lower A-arm Bushings, re-seal ARB compressor, alignment
220k -- New 295/70R18 Nitto Trail Grappler MT Tires
222k - New rear drive shaft
228k -- New Ignition Coil Packs
Known issues: While most maintenance issues have been repaired, this Landcruiser has been enjoyed outdoors and has some cosmetic defects. Also, the rear locker sometimes sticks and won't engage. The power antennae does not work. Please feel free to test drive in person. I will not ship the vehicle, but will pick you up at the airport, if you are flying in.
Thanks for looking.
Jeff
* 100 series, LX470
00S0S_hFk0YTlYpSz_600x450.jpg01515_dEBClD2QzUx_600x450.jpg00t0t_7Pco0jNKAZw_600x450.jpg00T0T_fhTRqfvnFVF_600x450.jpg00T0T_kgz1pmMf1dp_600x450.jpg00v0v_aNCLZHBXLh5_600x450.jpg00w0w_2a7cvfvUCPJ_600x450.jpg00Z0Z_aRrSBIOgEFL_600x450.jpg100e0e_a1l2z1M97lw_600x450.jpg
OverlandTheWorld
So is this the resonator or the muffler? I always though this was the muffler.
hitch-1-jpg.649058
Yes, the resonator was removed by PO, but it does have the muffler. The Muffler is between the axles, hard to see in the pic. I can get a pic in the daylight tomorrow or Fri.
gp01
